Looks like it might be.... that was a pic off FB. Chalk one up for the doorless Pilot to the rescue! LOLThat is awesome! Was the Jeep high centered?
I went through two sets of those shocks with poor results. They start rattling very shortly after install. Maybe you will have better results than me.I'm looking for a free day to head to the junk yard to build one too, but first I have to fix this squatting issue. I noticed the other day the rear driver side is leaning a bit to the left.
@b0wfin I contemplated getting the airbags, but I just read an old post on Piloteers about a good alternative - Monroe rear shocks #58645 Sensa-trac load adjusting shock absorber (coil over shock). They run about $68 a pair on Amazon. Has anyone tried these yet?
Replacement set of rear coil springs should fix a sagging issue .I'm looking for a free day to head to the junk yard to build one too, but first I have to fix this squatting issue. I noticed the other day the rear driver side is leaning a bit to the left.
I agree. That's on my list to replace as well.Replacement set of rear coil springs should fix a sagging issue .
Disregard my last. I will hopefully be swapping out the rear coil springs either this weekend or next weekend, then I'll replace the shocks.I agree. That's on my list to replace as well.
I have replaced the fluid and burnished the differential approximately 4 times. After my last off-road adventure the chirp went away, but so did rear wheel drive LOL. I am going to replace the differential with one from a newer Element or CR-V. Then I can test the capabilities again!Nice job on the repair. My ‘05 CRV had similar damage from a rear end collision. The Escalade had a bunch of front end damage. The rear axle chirp is resolved by replacing the fluid and doing a couple figure 8s in the parking lot. It’s called burnishing.
There you go...your first entry post into your own Pilot build thread. Post some pics and tips to help others.Disregard my last. I will hopefully be swapping out the rear coil springs either this weekend or next weekend, then I'll replace the shocks.
