Trying tp get on board air on my 02 TJ Sport. Always want my installs to be clean so this is really tough. Anyone have any suggestions let me know. I tried the plate under the brake booster but it's just too tight.
What on board air system are you trying to install? I have an ARB and I was able to install it near the brake booster. Ill get photos for you in moment.Trying tp get on board air on my 02 TJ Sport. Always want my installs to be clean so this is really tough. Anyone have any suggestions let me know. I tried the plate under the brake booster but it's just too tight.
Same setup. The plate under the brake booster is a good location for an ARB compressor:Fly_hippie Here are a few photos on how I fit my ARB near the brake booster. Its been in that exact spot for 5-6 years now. Not once single issue. I thought by now I would have burned it up being in the engine bay.![]()
Influencer III
19540
That’s a great price for the bond straps!today I bonded the Subaru and put LP Adventure rockslides on. everything was bonded, all doors, rear hatch and hood double bondedView attachment 163335View attachment 163333View attachment 163336View attachment 163337
Good paint job! Everything looks good!Purchased a used shell a couple months ago, had it painted to match the truck. Made a rack from 80/20 1020 1"x2" and 1"x1" with 2"x1/4" aluminum sides. Added an ARB awning to the zr2 this morning.
Now I don't need to carry a free standing awning In the back of the truck anymore. View attachment 163385
Trying to get as much ground plane as possible. When i transmit the more ground plane the stronger my signal will be. Hf signal needs as much ground plane as you can give it. So if i run 100watts, only 50 to 75watts may actually get out. So im increasing my chances of better performance.That’s a great price for the bond straps!
what was your reason for doing that, RFI in your radio gear?
Awsome evening picture.Last night we went to the top of one the local buttes so my wife could get some sunset and comet shots.
The first two are from my phone, the last three (the good ones) are done by my wife.
View attachment 163399View attachment 163400View attachment 163401View attachment 163403View attachment 163404
Influencer III
19540
You might be surprised by the small difference on the transmit results. Receive is definitely going to benefit. My rig is a police package Tahoe. It’s got bonding straps everywhere.Trying to get as much ground plane as possible. When i transmit the more ground plane the stronger my signal will be. Hf signal needs as much ground plane as you can give it. So if i run 100watts, only 50 to 75watts may actually get out. So im increasing my chances of better performance.
Beautiful shots!Last night we went to the top of one the local buttes so my wife could get some sunset and comet shots.
How well does a dodge power steering pump fit on a Ford Bronco ? How will you install the winch on the Bronco with the stock bumper ?yesterday the “Adventure Machine” developed
the notorious steering whine. I decided long ago I was going to convert over to a Saginaw power steering system for better pressures, steering response and reliability. So I went and stole the power steering pump, winch and Auxiliary Lights
from my Ram. Today I start the Saginaw swap and install my winch. Pics to fallow.
Did you mean GROUNDING STRAPS ? Is that for better radio communications ?today I bonded the Subaru and put LP Adventure rockslides on. everything was bonded, all doors, rear hatch and hood double bondedView attachment 163335View attachment 163333View attachment 163336View attachment 163337
Influencer III
19540
Saginaw is actually GM. The auto industry is a little bit incestuous. Lol.How well does a dodge power steering pump fit on a Ford Bronco ? How will you install the winch on the Bronco with the stock bumper ?
