I have a RESMED CPAP too. When I return home from business I have an appointment at the Dentist to find out about getting a dental appliance. These are supposed to be a decent alternative to use on a plane, and in this case, out in the boondocks. No power needed. They aren’t cheap, and insurance doesn’t cover it since they are already paying for the regular CPAP. I’m on an ADV, so weight is always a concern. CPAP and battery pack is very heavy.
Anyone have any experience with these.
Follow up on the dental appliance to replace my CPAP off grid:
I got fitted, by my dentist, (it's an exact process, and an absolute must! DIY is potentially harmful to your jaw) for the appliance and have been using it several times for the last month. It works great! I sleep as well with it as I do with my ResMed. You do wake up with dry mouth, there is no humidifier tank.
The device goes into place on your top and bottom teeth then you hook up the bottom and top and set the adjustment for what suites you. The device holds your bottom jaw forward and keeps your airway open. One positive side effect is if you grind your teeth, you won't any more.
No power, no batteries, much less space, and almost 0 weight. This is a big consideration for me when I'm on the ADV, not so much in the truck. They work great on long flights too. First time I've slept on a long haul flight in almost 20 years!
The one drawback might be the price, depends on how you look at it. Mine was $1700.00. To me it's worth every penny.
Hope this is helpful.
