Ahh thanks for the link for the correct one.
Expedition Master I
1537
It's still not the correct one for the tank in question. I'll say it again but the Worthington and Manchester 5lb tanks are not the same diameter.Ahh thanks for the link for the correct one.
Sorry I totally missed this. I got the hose locally at Canadian tire. It was similar to this one.Can you link to the 10 foot hose? I would like to use my new tank on my heater and stove.
That’s a nice looking trailer set up you have. Really clean looking. Something similar is on my bucket list. Nice job.I bought my tank & mount from AT Overland. I fabricated the bracket that attached to the trailer chassis.
View attachment 67924 View attachment 67925
Heh - I recycle the ones I find in the woods - came in handy last year when we were out of power for a week after the hurricane and I only had 1 20# propane tank with any propane in it at ALL (partly because I'd filled a bunch of 1# ones before the storm).This little adapter will allow you to fill the disposable tanks
http://a.co/d/6qbKrgf
I plan to pick one of these up eventually
Well I can honestly say I have tried just about every burner on the market. Granted my setup is a little more elaborate but the main reason is the burners, stoves, ovens, heaters, showers and other items almost all require LP Gas. They can all drink from the same source. That's probably why the use of white gas or unleaded is not as popular. I do have a single multi gas burner that I have used on the KTM when camping off the bike. It works fine with single skillet application however when I carry my backpacker oven (below) the burner sits directly under the oven and would encloses it and I don't want to heat the gas. I never use the two burner stoves that are typically seen today either, I like a better control over the heat that you don't get with white/ unleaded gas or LP gas. I use butane burners. Much better control of over the heat. I have an overkill setup but sometimes I use 4 butane burners with the grill and a flattop. I usually end up cooking for the group anyway. Yea I know overkill I do most things like that. But hey everyone likes a fresh ground pour over in the AM. Yeah, I have been known to grind my own coffee beans when camping.How come liquid-fuel burners are not more popular?
I had a Coleman single-burner in the past that was great, and now have a dual-burner that is even better. On medium heat with one burner (stir fry meals, eggs, etc), I am looking at about 8 hours or more of cook time on one fill. That is perhaps a week on a single tank of fuel, which is also about $0.75 in gasoline. And, if I am going out that long, I already have jerry cans with me, so that is one less thing I need to carry or stock.
Am I missing something?
Expedition Master III
FYI Im a X not a frontier, so no bed, and the interior is for things I need often and want to avoid getting weathered.They seem to be a perfect fit, but no base 'tie-in' except the can next to it and the small rail lip. So that setup only relies on a strap to secure it.to the rack. I see that you carry 5 water and 1 fuel, and that is a lot of weight high-up. Have you found instability concerns either on road with a emergency avoidance, or top-heavy instability in off-road/off-camber situations? Being above the bed rail, wouldn't it be better to put them right below in the bed, and use that vacated space for lighter equipment?
Note: I realize this is not as high as putting them on a roof rack(fuel/water) but physics still come into play.
I like this setup. Seems to be what they use in Africa/Australia, along with many here in the States. That pictured aluminum storage cradle is sweet, but as stated, wickedly expensive ($100-range). Ad in the clamps, and bottle, and Your pushing $300.00Welcome to the club. I got to a point and I just couldn’t stand using them or seeing them thrown in the woods anymore. I have a custom tank holder held in place by a Fourtreks mount. Old pictures but you can see it well enough.
View attachment 65832 View attachment 65833
Expedition Master I
1537
Unfortunately when nobody makes what you need your options are limited. I bought the cradle for $105, the Fourtreks mount for $54, and the bottle for $60. I don’t think that’s bad at all, especially when you consider you’re buying the bottle regardless. I could have done it without the Fourtreks mount but I wanted the cradle to be easily removable and I trust Fourtreks to hold a number of things in place on my rack. It’s custom, exactly what I wanted, and it safely/securely does the job.I like this setup. Seems to be what they use in Africa/Australia, along with many here in the States. That pictured aluminum storage cradle is sweet, but as stated, wickedly expensive ($100-range). Ad in the claps, and bottle, and Your pushing $300.00
Nice setup on your X! I’m a Nissan guy and always loved them.FYI Im a X not a frontier, so no bed, and the interior is for things I need often and want to avoid getting weathered.
I do run a strap thru the handles and secure it to the gobi when traveling. As for weight. Its @110lbs. My empty rooftop tent weights more than that. When fully rigged up, yes you feel it. Is it a concern? Off chamber maybe, 99% of the time, no. Heck the gobi rack weights more than the full cans come to think of it. I still do have the ability to add a 2nd row of the cans as mentioned in the original post, I have more than enough cans to do it. Add 10gallons on the rear bumper, and 3gallons underneath where the spare use to reside. With a single row as shown if all fuel, that is 28 gallons. typically I carry @50/50 fuel and water. This setup you see would make 12.5 gallons water, then 15.5 gallons of fuel. 95% of the time I go out, I only need a 5gallon water and a 5gallon fuel on the bumper. I keep the 5lb propane on rack with the mount shown earlier, and a medium plano 1719 case up there next to it. Fits like a glove in the recessed area of the Xterra gobi racks. Again all secured. I just don't show the rigging in the photos. For the Plano cases, I like using Raingler nets. Have vehicle specific nets to hold spare JIC cold weather and wet weather gear that stays in the rig all year since its space that is never used for anything else. And a variaty of universal nets on the roof etc.
Here was the previous setup of rotopax... which I am not a fan of. First, the delivered fuel spouts are garbage, so you need to spend $10 more to get a decent spout, they need to burped often and will still bulge like the blueberry girl from the old Wonka movie, the mounts are stupid expensive and the cans even more so, people complain about the price of USGI or other mil spec cans but then buy rotopax.... which cost more and carry less??? Anyways, they do have great customer service and are local, but I would opt for sceptre cans personally. But the rotopax were lower profile but carried half the liquid, again for more money.
Typical load out next to a nice FJ similar equipped.
Heres my rotopax complaint part. When you buy your bumper, carrying fuel and water is one of the things most look for just like moving the spare to the rear if it is not already there (like the X). For my cans, the water can be had at buyLCI for $24. Fuel cans can be hard to find and cost a bit more, but I just found one for $99.50 on ebay (I did pay less but had to go thru a bit of a hassle to get them), $19 for the fuel spout, and a $5 ratchet strap to secure them. So when I spec'ed my bumper I opted for these can mounts. It cost about $200 to add these mounts when I ordered the bumper. To do rotopax mounts shrockwroks charge @220 including mounts and extensions to hold 4 cans total (the also sell cans but not at a discount). Dual 2gallon rotopax cost 160, add 20 for the spouts, dual 2gallon water cost $100. Total for each setup would be 200+100+24+19+5= 348 for mil cans. OR 220+160+100+20= 510 for rotopax... Yeah right, but we (USGI guys) are still carrying 1 gallon extra fuel and water and its typically a great deal cheaper. But sometimes you can buy the rotopax "blem" units for a great price.
