kunstmilch
Pomona, CA, USA
Erich
Wise
GMRS call sign: WRFL229
After having Timken hub assemblies put on the suburban, the ABS light went off on a trip up to San Jacinto. Turns out the Tires rubbed the ABS sensor wires...While Timken bearings and hubs are the OEM the sensors it turns out are not...and so OF COURSE they are just different enough.
Taking the truck in today to have GM sensors put on both and adding extra sleeve protection to the wires for peace of mind.
Sparksalot
Influencer III
4,312
Bastrop County, TX, USA
Rex
Drake
KI5GH
Air Force
What year is your burb? The sensors are dirt simple to change on thecopcar.
Reactions: DaleRF
3rdgentoy
Riverside, CA, USA
Luke
Esposito
Not today but yesterday I made a “custom diy” version of the lemmeout mod for my runner. It seemed like a simple concept and I couldn’t justify paying $80-$100 for something I could make myself for $15 at Home Depot
Got a DIY on what you did?
Yeah sorry for late reply. I used a key ring, abrasion resistant string, nylon tubing and a carabiner strap all from Home Depot. I unbolted the hatch latch from the trunk and put the key ring around the latch, ran the nylon tubing around the string for extra perfection, tied the string to the key ring and just ran the string following the already existing wires for the latch (loosely zip tied it to the wires to keep it at that angle) i popped out one of the plastic screws hole things from the black metal part underneath the interior plastic for the hatch ran the string through there and just drilled a hole in the plastic interior part so I can tie it to the strap and access it from inside. Let me know if any of this is confusing or you need pictures haha sorry
CR-Venturer
Ardrossan, AB, Canada
Jas
Spr
The only thing you forgot was to put some kind of amusing message on the strap :D
Reactions: 3rdgentoy
kunstmilch
Pomona, CA, USA
Erich
Wise
1999 Im sure its simple but they are gonna change them for free and i have a good relationship with Reynold’s Buick GMC. Otherwise i would be doing it.
Reactions: Sparksalot
kunstmilch
Pomona, CA, USA
Erich
Wise
Well here’s the original equipment sensors. The originals lasted 260,xxx miles so I imagine I should be good to go.
05EXCURSION
Renton, King County, Washington, United States
Jason
Lujan
Finally took the time to do an alignment on my excursion and fix the centering pin on the rear axle I knew it was out but but not that far out. Next project is to ajust the caster will cut the welds on the outer axle tubs and set them to the proper angle
Downs
Hunt County Texas
Joshua
Downs
KK6RBI / WQYH678
USMC 03-16, FIRE/EMS
Kinda related to my Jeeps as it's where I keep them.
With the CJ2 project coming to an end, it was time for a big purge and reorganizing of the shop. I still need to go through the shelves, but that's a whole job in and of itself. I also ran out of garbage can space, ha.
I also tore down the Carter WO carb the previous owner sent with me in a box of parts for a rebuild. They put a Solex on it, which is actually fuelling the Jeep VERY well. I'm not sure if I want to rebuild this and put it on the shelf as a spare, put it back on the Jeep in place of the Solex or start an exchange/overhaul program of sorts for the old Jeep community.
DaleRF
Pioneer II
8,178
Sierra Vista Southeast, AZ, USA
DALE
FOLLETTE
KJ7JDA
US Army CWO (Ret)
Great lookin' Shop!
El-Dracho
Ambassador, Europe
Supporter
Protector I
13,461
Lampertheim, Germany
Bjoern
Eldracher
DO3BE
That´s a great workshop!
Reactions: Downs
