With the primary electrics done I can move on to the plumbing work.
The upper coolant connection was straight forward thanks to the modifications to the radiator's inlet port, just a simple 45-degree 1.75" layered silicone hose with stainless t-bolt clamps that I'm using throughout:
These "U" and "J" bends make fabrication easy, even without a bender, & with very smooth transitions thanks to the mandrel bending machine that makes them. I would like to use stainless steel tubing, but until I get my own TIG welder I'll use this heavy gauge steel exhaust pipe that I can easily MIG weld:
The lower coolant pipe I made is a 45-degree elbow with a short leg on 1 side to join the 2 hoses, with beads formed using the modified vise-grip:
The engine's new coolant inlet connection uses a short 2" diameter hose, then the new elbow, & down to the radiator with a 90-degree elbow hose:
Before I moved onto the charge piping I needed to do some welding experiments with different weld puddle techniques, tubing gauge, plated vs raw steel, gap vs flush, & taper angle in the joints between them (plus a not so subtle joke for a friend). Best welds I made were with .024" wire, a fast u-shape drag, 14 gauge unplated tube, 30-degree joint taper, & little to no gap:
Plenty of figuring & marking to keep me from messing up as I started with the hot-side charge piping, all in 2.5" diameter. Glad I got a bunch of practice building a header & full exhaust system for another project before digging into this more detailed build:
My hot-side pipe turned out as smooth & short as I could've hoped for. From a v-banded aluminum elbow off the Super HX30, to a silicone hump hose, then the new pipe, & into the Freightliner charge cooler with a reinforced silicone coupler:
The cold-side charge pipe wasn't much more complicated on the other side of the engine, with pair of 90-degree bends linked together & the same compliment of hoses:
Grinding the welds back wasn't necessary, more for fun than anything... at least until I learn TIG that's more well suited for this kind of work:
Next up I'll build a turbo dump pipe as paint dries on the new pipes, then it's on to fluid fill ups!
