We did similar on our in 2008 except with just spray paint. It still looks the same as it did 11 years ago. Nice job on yours, I like the color...
Saggy headliners are the worst! I feel like I should've been more patient & used a bedliner coating that was custom tinted to match the interior color like it looks like you've done with that spray paint.Could you educate me about this in your build notes:
[~ Tires: 37-39" so I can start utilizing more inexpensive military surplus bias-ply rubber]
Also, I did read through the entire thread but I could not find the actual tire size:
Could you give me the specs on the ones you have on it in the Hummer bead lock video?
A vanity question:
If you were to go back and go with the "Steelie" solution with the welded bead lock, would it have the same aesthetic look like the ones you have on there now?
The final question:
What is the lift height you have on your rig and is it body and suspension lift or one or the other??
Best,
Tex
Hey thanks! I keep trying to push the line of what I do know how to do, with what I want to do, so I can keep learning new things. No shortage of new things for me with this project.The creative and fabrication skill you posses are amazing. I thought of myself as a DIY'r until i stumbled across this thread. Well done.
It's a handful for sure. But there's a good alternative for that in the form of a busbar. You could run a single big cable from the battery post to a busbar (blue sea example pictured below, but they come in all shapes & sizes) in a remote/better location, then link to it with all the remaining cables you had on your post previous. I'm planning to use several busbars: 1 negative + 1 positive each on either side of the engine bay, one side to run a circuit for "clean" power that'll feed loads like radios/computers that are sensitive to fluctuations, & the other side to run "dirty" power for loads that don't mind fluctuation or have extra high demands.I wish there was a better way to route all the different terminals/terminations to the battery posts. I have a 2 battery system and an isolator and I hate all the connects at the battery(s) It makes it so difficult to remove /replace batteries when needed. I used the same gauge wire and connector system on mine but not the same primary pole connector. Yours looks fantastic. I just saved the info on the Blue Sea unit. I like the functionality of it.
As always it's looking amazing!
Best,
Tony
An electric Disco would be very interesting! Feel free to send it along, I'll gladly offer any advice I can. I keep wanting to post more of the build on other forums... but there are so many of them! Maybe I need to write a script to do it for me, to mirror it in relevant forums.I looked those up on Google after I posted this and there is definitely a lot to choose from. I had been planning on having a 4.6 from Warner shipped into replac4e the 3.9 with 400,000 miles on it (Still running well with admittedly less than new power) But I have decided instead to go all electric. I will be doing the lift and military wheel upgrade this year and then the conversion next year. I will post the build when it gets out of the planning stage.
FYI.....This might be a little overkill but on those 2.0 connectors, I added solder to them and then used the crimper. I have had those pull off before and although I cannot remember the circumstances of why I went with the "I tear everything I touch up " rule ...:)
I am going to private message you, I have some Youtube production questions for you, and I have already rambled on to long on this thread...
Lastly, I posted links and comments on your work to this thread to the other clubs I'm in or forums I am part of:
Land Rovers Only
Land Rover Forums
Texas Land Rovers
Southern New Hampshire Land Rovers Club
D1 Landy club [Facebook]
All Land Rover{Facebook]
Landy Zone UK
Donegal Overlanding [Facebook]
Best,
Tony
Oh I feel you with the potential disaster though! Even after all this work the fear of a runaway is real after all the turbo & fuel mods I've done. I think I might CNC a chunk of wood to fit the turbo inlet perfect with something funny engraved on itDude, all of this looks good! I haven't been on this forum in a while and just read through the thread. Everything seems thought through and not a hack job at all (unlike my engine swap which I'm basically expecting to burst into flames spontaneously). ha. Speaking of spontaneous fires, what are your plans for the electrics? Like all the little factory bits. I kept the rover ecu and harness to do non-engine/trans trans stuff but its kinda a messy nightmare.
