Here's a little background on shock manufactures.I have read that fox were stiff on road. hmmmm pretty cool to hear other wise. I may go that route then.
Unless you buy something that can be tuned to order, off the shelf shocks are a crap-shoot regardless of manufacture.
It kind of works like this.
You have four similar vehicles. The factory will install a shock that's well balanced for a stock configuration. Four different shocks.
Now we go aftermarket. The shock manufacture will use one shock and weld on different ends to fit all four.
Vehicle 2-3 the shock works well. Vehicle 1 says their too soft and vehicle 4 says too stiff.
Lets say you want something out of the box that's tuned. You call King Shock. You weigh all four corners then you weigh tire/rim, suspension...everything that's on the corner but not body (unsprung weight). Give them this info.
That's the proper way buy shocks. The better manufactures, that specialize in your vehicle, will have something close. But, there's no way anyone knows what your unsprung weight is. So you hope for the best.
