Diamondback Bedcover is on!
Well... I still have to install the two front toolboxes I ordered and make some final adjustments to how tight the front portions latches down.
My first impression is... it is of Extremely High Quality! Great wields and super easy to install. It does indeed take longer than the estimated 45min to install one. I could see doing it that fast if I had installed one before... didn't have to cut off all of the protective packaging/tags... and knew exactly what tools were needed before hand... and had an extra set of hands at a few points.
However, once the initial setup is done. I can totally have it removed in about 10mins and re-installed in about 10 to 15mins. The individual panels can be either fully removed or folded over (flat) in a few seconds.
I have some plans for this puppy! It feels super sturdy when I walk around on it. I am a 200lb man too!
I plan to go on a trip to the Outer Banks this weekend. It will be a lockable and water tight trunk now. My truck bed is super deep = lots of storage down low. Plus I can throw stuff like a fridge or 4 x 8 sheets of plywood up top (or firewood when camping).
The first two pics below are when I first set it onto the top of the bed for a lookover after unboxing. I will throw the giant box & wood crate up on top and take it to the dump this weekend.
In some of the pics you can see that the Diamondback Cover's latch points are in a VERY GOOD spot on the Colorado. It uses the bolt holes where the factory ladder racks mount. I just had to pop off the rubber covers and put a sticky protective plastic piece in to protect the paint from vibes. The middle beam is the main clamping force for the cover.
All hardware is stainless and strong. The latch brackets are aluminum though... but used for pulling the cover down and don't take a load. So they will be more than adequate for that job. The gas struts are rated @ 80lbs each. Two of each on both front/rear panels.
My pedal drive fishing kayak will continue to be Super Easy to load/unload with this cover. I did the measurements and will be able to close the lid once the kayak is in the bed. The pedal drive will still clear the lid and I don't have to remove it.
View attachment 88603View attachment 88604View attachment 88605
