Rusty burbin
Hesperia, CA 92345, USA
Jonah
Gregg
Picked up my 4l80e at the junkyard yesterday. It's as you'd expect. Greasy and in need of a rebuild but I have a good solid base to start with.
Rustyburbin from SoCal 5 kids, wife, dog and a 1970 K20 Suburban
utspoolup
Murray Utah
I do not know. I didn't even see it till you mentioned it. My wife snuck off with it to go do taxes, so when I see it again Ill will check to see what is there.
Did you crop the photo? I have seen glare like this before if you have a REALLY bright light hit the lens. If you look at filtered photos of cars with lightbars on you will see the same thing... Check out this photo of Dave (Maxterra also on here...)
http://s619.photobucket.com/user/maxterra/media/Xterra Projects/IMG_9807__zpsjatknj76.jpg.html
You will see something similar from his light bar on the bumper making the green dots. I just can not find your source unless it is the sun itself.
utspoolup
Murray Utah
Oh, I also finished my wind deflector.... OLB representing in Utah now. Oddly I had 2 guys honk and wave while out getting groceries just now. Still looking forward to a weekend with good weather to install the new leaf pack. We got 4" of snow, but it is now nearly 50 outside and it is melting FAST, have a bad feeling a few guys from work are going to call about flooding soon.
[yoda voice] The force is strong with this one, yes [end yoda voice]
4xFar Adventures
Benefactor
4,826
San Francisco,CA
Brenton
Corns
I drove the truck for the first time since 1/23/2017! Still not ready to just jump in an out, but the medical boot and my regular boot have just enough room to not get in the way of each other. Just as I was getting my crutches in the back seat, the church across the street had their Palm Sunday procession around the block. I thought they were praying for me at first!
yabbaz
Richmond, VA
got my auxiliary reverse lights installed. Really like these things... planning on using them for most of my exterior lighting now too. Figured id chuck em as reverse lights to test them out first but DAMN these things are bright. they have a high & low mode so they SHOULD be good for work/aux lighting but we'll see. so far i like what I see.
Reactions: PNWInfernoPro
KD7WCD
Tempe, AZ, USA
Jayson
Adamsen
KD7WCD
If the overall length is shorter than what you removed then I would return them or call and ask them why they're shorter.
Even though you can raise the vehicle further than before you're still limiting yourself with those new dampers due to reduced droop which also limits articulation.
Having more height is good but articulation is what you really want and to reduce that is taking a step backwards.
Sent from my SAMSUNG-SM-T337A using Tapatalk
That was kind of my thought but if the proof is in the pudding then the pudding is good. Any one who has done the lift I originally did with the spacers can tell you about the CLUNK that one gets in tbe upper control arm. With this set up that is all gone and I still gained half an inch of clearance. Still say that there is still some sort of black magic going on but it has been a diffident improvement. [emoji106]
Sent from my GT-N8013 using OB Talk mobile app
Reactions: macr88
macr88
Expedition Master III
5,643
Emmett, ID, USA
Mac
Raslan
KJ7TLH or GMRS WRBM678
Sweet District II
Ah ok, didn't realize that the additional length came from a spacer.
KD7WCD
Tempe, AZ, USA
Jayson
Adamsen
KD7WCD
Well no you are not that far off.nthe new set does not use tne spacers. If you look at it, the shocks are about the same lenght.
Reactions: 9Mike2
Mike W
3,833
Iowa, USA
IowaLR4
Do you use standard paint brushes to apply the reformer and barrier? Never thought about doing this but I can see the value- your underbody looks so nice! No double-entendre intended.
I use the little 1.25" foam brushes to apply most of it. Cleanup and prep takes the most time.
Once I use the converter I will go back over it with the rubberized coating. It can be very time consuming. I may need to pull my sliders off to get them fixed properly.
