I fully agree and would like to push the idea of having a Fire Extinguisher with a hose/nozzle.... i also recommend that you get one with a Hose/Nozzle, then you can pop the hood, stick it under, and pull the trigger, instead of having to open the hood all the way.
In Australian we have a grass call Spinifex.
If you drive through Spinifex when it is dry it pack itself up between the under-body armour, exhaust and vehicle body. When it catches on fire it is hard to put out with a fire extinguisher with NO hose. Some fire extinguishers will not work on their side or upside down. This makes it hard to put an under-vehicle fire out, unless you have very high clearance. If the fire extinguisher HAS a hose/nozzle it makes it a bit easier to feed the hose under the vehicle.
The suggestion if driving in Spinifex country every time you stop for a break, pull out any build-up of Spinifex from under the vehicle. A piece of fencing wire with a hook is handy for this. Stops you burning your hands on exhaust.
Colin I totally agree with you there Colin they are more affective
It's plastic. Buy a ALL metal unitSo is there anything wrong with a $17 Walmart extinguisher? https://www.walmart.com/ip/42732928?wmlspartner=wlpa&adid=22222222227031385589&wl0=&wl1=g&wl2=c&wl3=53491285472&wl4=pla-112239024512&wl5=9010927&wl6=&wl7=&wl8=&wl9=pla_multichannel&wl10=8175035&wl11=online&wl12=42732928&wl13=&veh=sem#about-item
Other than the no hose thing.
Well that makes more sense I never thought about it that way.It's plastic. Buy a ALL metal unit
@cam_toyota_tech
I like the idea of keeping it close to the driver as that is where it will be needed during an emergency. I always thought mounting it to a roll bar or in the back may prevent the driver from reaching the extinguisher.I have mine mounted where I can access it immediately.
Only downside is if a short person needs to drive my Jeep they will have to remove the extinguisher from its mount in order to move the seat forward. That is not a problem within my own household, but it would be a deal killer for others.
Mine is mounted between the driver's seat and the door and has a plastic holder that allows it to be ripped out pretty quickly for emergencies.
Good place for sure, I say that one of your fire extinguishers should be at arms reach when you are strapped in. That be wheels down or if you find yourself wheels upI like the idea of keeping it close to the driver as that is where it will be needed during an emergency. I always thought mounting it to a roll bar or in the back may prevent the driver from reaching the extinguisher.
