Fuso FG slow build
atIOIYIOI
Kingston, Ontario
Bruce
Robertson
VA3BWR
Fire Rescue
With paint finally back on the inside of the cab floor, I started adding some sound damper to help cut down on engine and road noise. This stuff is pretty straightforward to apply, and gives a nice finish when it’s done.
Lining the Fuso cab floor with Noico!
atIOIYIOI
Kingston, Ontario
Bruce
Robertson
VA3BWR
Fire Rescue
One thing I had been avoiding was replacing the batteries, since I knew the truck was still going to be idle for a while - but I decided that I was sick of boosting the truck every time I needed to move it, so battery replacement time it is!
Mitsubishi Fuso battery replacement
atIOIYIOI
Kingston, Ontario
Bruce
Robertson
VA3BWR
Fire Rescue
Oh boy, I’ve got some catching up to do in this thread!!
The first step in building an overlander, was sorting out what was going on with the chassis, and sub-frame - so, time to cut off the old and start building!!
Mitsubishi Fuso FG Camper Sub-frame build - Part 1
atIOIYIOI
Kingston, Ontario
Bruce
Robertson
VA3BWR
Fire Rescue
With the sub-frame removed, I could figure out what goes on with the chassis, when it gets twisted up. Or, at least, I could get confirmation that I didn’t know what I thought I knew.... with this understanding, Ill hopefully be able to avoid stressing the composite habitat box, and not concentrate stress on the chassis.
Mitsubishi Fuso FG Camper Sub-frame build - Part 2: Chassis Flex
atIOIYIOI
Kingston, Ontario
Bruce
Robertson
VA3BWR
Fire Rescue
While working on the design of the sub-frame, I thought it was a good time to tackle some of the diagnostics of the fault codes I had going on....
Mitsubishi Fuso FG 4P10 crankcase pressure diagnostic 1
atIOIYIOI
Kingston, Ontario
Bruce
Robertson
VA3BWR
Fire Rescue
And, since things are never as simple as we want, this was going to take some good head scratching to sort out.
Mitsubishi Fuso FG 4P10 crankcase pressure diagnostic 2
atIOIYIOI
Kingston, Ontario
Bruce
Robertson
VA3BWR
Fire Rescue
Even the most complicated problems have solutions, and eventually, I got there!
Mitsubishi Fuso FG 4P10 crankcase pressure diagnostic 3
atIOIYIOI
Kingston, Ontario
Bruce
Robertson
VA3BWR
Fire Rescue
So, now back to this idea of preventing the stress of the chassis from getting into the composite box... time to try out making a spring mount!
Fuso FG Chassis to Sub-Frame spring mounts - DIY build!
atIOIYIOI
Kingston, Ontario
Bruce
Robertson
VA3BWR
Fire Rescue
And since I was now actually moving the truck around a bit, I figure it’s time to get some fresh oil in there!
HOW TO Mitsubishi Fuso Canter 4P10 engine oil change!
Reactions: DintDobbs
atIOIYIOI
Kingston, Ontario
Bruce
Robertson
VA3BWR
Fire Rescue
Now it’s time to start building the sub-frame/flat deck!
Mitsubishi Fuso FG flatbed / tray back build part 1
atIOIYIOI
Kingston, Ontario
Bruce
Robertson
VA3BWR
Fire Rescue
The sides and deck will be connected using T-slot extrusion, which will also allow for the future attachment of the storage boxes that will go below the deck.
Mitsubishi Fuso FG flatbed / tray back build part 2
atIOIYIOI
Kingston, Ontario
Bruce
Robertson
VA3BWR
Fire Rescue
And, sometimes, you have to work backwards to fix an earlier oversight...
Mitsubishi Fuso FG flatbed / tray back build part 3
atIOIYIOI
Kingston, Ontario
Bruce
Robertson
VA3BWR
Fire Rescue
The front end of the flat deck will need to have some sort of protection for the back of the cab, but I don’t want anything huge...
Mitsubishi Fuso FG Canter - such a 1/2 headache!
atIOIYIOI
Kingston, Ontario
Bruce
Robertson
VA3BWR
Fire Rescue
Is that it? All done? (Just a hint, nothing is ever done!). It kind of FEELS like this is getting close though!
Mitsubishi Fuso FG flatbed / tray back steel wrap up
atIOIYIOI
Kingston, Ontario
Bruce
Robertson
VA3BWR
Fire Rescue
Time to get a bit more caught up in this thread!!
Supply Run - a quick adventure into Quebec
atIOIYIOI
Kingston, Ontario
Bruce
Robertson
VA3BWR
Fire Rescue
With the composite panels on hand, let’s take a closer look at what they are!
Mitsubishi Fuso Camper Build - Using composite panels
atIOIYIOI
Kingston, Ontario
Bruce
Robertson
VA3BWR
Fire Rescue
And it’s now time to start on the aluminum structure to hold the panels!
Mitsubishi Fuso Camper build - TIG welding the aluminum floor structure part 1
atIOIYIOI
Kingston, Ontario
Bruce
Robertson
VA3BWR
Fire Rescue
More TIG welding - warning, there is a lot of welding coming!!
Mitsubishi Fuso Camper build - Aluminum floor TIG welding #2
atIOIYIOI
Kingston, Ontario
Bruce
Robertson
VA3BWR
Fire Rescue
Like I said.... there is a lot more welding!
Mitsubishi Fuso Camper Build - I’m Floored with TIG welding #3
atIOIYIOI
Kingston, Ontario
Bruce
Robertson
VA3BWR
Fire Rescue
With the floor starting to take shape, and decent weather, it was time to start tackling the nasty RUST on the chassis!!
Mitsubishi Fuso FG chassis 911! De-cRUSTification!
