Good point as your just reminded me my exhaust on the power stroke was like 1800+ degrees. Makes complete sense that it would be a danger in wooded areas. I didn’t evan realize it. Thanks!A word of caution with modern diesel. Current models have a very complex and unreliable emissions system. Gone are the days of 500,000 mile light and medium duty diesels. Most engines life span has been effectively halved by the emissions equipment. Then there's the fact that the exhausts run up to 2400* during something called DPF regeneration, that's hot enough to start brush fires. Extended idling and babying will kill a modern diesel as well. Let it run for a minute or two then put it to work.
Just want you to be aware, modern diesels cost more, dont last as long, cost more to maintain, and are less reliable than a gas engine. But when it comes to carrying a load, there's still no substitute.
I am also concerned with diesel when traveling outside the US with it. Canada not so much, but anything south will be an issue with the type of diesel they use.
