Lodge Hibachi grill. Worked great for our Black Hills trip since ground fires are verboten and there's plenty of pinecones. We have a 3 burner stove but sending the kids off to collect firewood (or pinecones) is an essential part of any trip.
I love my coffee, or as we call it where I am from Swedish Gasoline!
I use a simple pour over set up for my coffee.
What do you use?
Is there no end to snow peaks gear. Got admit it there gear is top notch worth the £€$![]()
Snow peak Titanium French Press and Caffee Latte Set. Don't use the frother much but its there when my wife wants some froth with her hot chocolate. It's light and easy and will last 100 years. Love it.
You need a finer grind of coffee. It's not the filter pore size, it's the size of the individual particles of coffee that are affecting strength. With a smaller particle size, the surface area is increased, and more coffee can be extracted. Different coffee beans certainly affect apparent "strength" too. Espresso beans, or any coffee with a darker roast, will give you stronger, but not necessarily better, coffee. This is how Starbucks (Charbucks) makes a strong coffee for the mass market which is usually dumbed down with milk, sugar and other additives.View attachment 51426
I tried out my new GSI Drip Coffee maker this weekend. Super easy to use and clean, but makes kinda weak coffee. The water goes through the filter too quickly. Maybe need to add more coffee grounds. I'll keep experimenting.
Lower the filter so it sits in the water, lift up to drain when it’s strong enough. Use it like a French press instead of a drip machine.View attachment 51426
I also prefer pour-over. I don't like French Press. Plus, pour-over is easier to clean if you use a paper filter. I just got a new GSI pour-over setup.Pour over is a good simple approach for a great cup, but yeah, it's also totally hipster. I should know, I've got a Chemex I use at home...
You can try a couple things; maybe try them together. First, for cone filters, you might try a finer grind. That will hold the water in the filter basket longer and make the flavor stronger. Also, try tamping down the coffee slightly after it's in the basket. that will also slow the rate of flow. Hope it helps.View attachment 51426
Snow Peak does make some great gear. Their quality control seems to be far above other brands.I picked up the SnowPeak coffee grinder recently. It's simple and bomber like most of their gear. Recommended!
View attachment 49108 View attachment 49109 View attachment 49110
