- First Name
- Tom
- Last Name
- Houston
- Member #
8300
- Ham/GMRS Callsign
- WØNUT Extra
That is an old wives tail. I have run CO2 for 20 years. I may drop 5 lbs in 6 months.
Even a ten gallon size tank alone will not be enough to fill all your 35's back up, But with the compressor refilling the tank at the same time it will work. The train Air horns all depend on how much air you use with each blast. The idea of the tank is act as a capacitor bank to not delete all the air at once that a compressor would have a hard time keeping up with , Volume vs Pressure ...
Ok. What is the smallest CO2 tank that can inflate four 37s from 0psi to 30psi? Space is at premium so I am asking for the smallest. Thx.
37/12.5/17. I'm now on 315/17 but planning ahead. [emoji5]
Inflate pressure from 15psi to 30psi on trail but I said from 0psi for some reserve just in case (ie. seat a bead).
I am looking at minimal space/volume, the smallest co2 tank. I do have an arb compressor under the hood for backup.
It looks like 5lbs will give me what I want plus a couple of extra friends on the trail. Hahaha.The formula for it’s volume is R squared times D times PI squared, where R is the Radius of the doughnut and D is the diameter from the center of the doughnut across the hole to the center of the doughnut on the other side.
Say your tire is a 37 - 12.5 - 17. The tire is about 12.5 inches across at the sidewall, so R is 6.25. The diameter from the center of the sidewall across the hub is about 22 inches. So the volume of the tire is 6 times 6 times 22 times 9.8696…, but 9.9 will work fine. That calculates to 7841 cubic inches. Divide by 1728, the number of cubic inches in a cubic foot, and you get a tire volume of about 4.5 cubic feet. Of course you can work entirely in cubic inches, too.
To figure out how much air it takes to inflate it, it is easiest to think in atmospheres, or multiples of atmospheric pressure of about 15 PSI. If you shove 4.5 cubic feet of air into your tire, the pressure will go up by 1 atmosphere, or 15 PSI. If you want to air up from 10 PSI to 25 PSI, put in 4.5 cubic feet. To bring it up from totally flat to 25 PSI, or increase pressure by 1.67 atmospheres (25/15), will take about 7.5 cubic feet – 4.5 times 1.67.
And how big a tank do you need? Lets say you want to air up your 4.5 cubic foot tires from 15 PSI to 30 PSI. That’s an increase of 1 atmospheres (15/15), so you need 18 cubic feet of air (1 X 4.5 X 4). If you fill your tank to 150 PSI, that’s 10 atmospheres. Air will stop going into the tire when the tank pressure equals the tire pressure of 30 PSI, or 2 atmospheres, so you have 8 atmospheres available. Subtracting one more atmosphere will leave about 15 PSI in the tank when you finish, so with a reserve you have 7 atmospheres usable. Consequently it will take a 2.57 cubic foot tank (18 / 7). ~ calculations from Jim_Lou from off-road.com and modified by me to meet your criteria.
The conversion rate from liquid to gas from a CO2 tank is one pound liquid = 8.741 cubic ft of gas, so a:
5lb CO2 cylider would hold 44 cu ft. @ 850psi
10lb CO2 cylider would hold 88 cu ft. @ 850psi
20lb CO2 cylider would hold 175 cu ft. @ 850psi
So, for every pound of CO2 you would get 3.4 fills (4 tires from 15psi to 30psi) ie (8.741 / 2.57).
Or, a 5lb CO2 cylinder would give you 17 fills (4 tires from 15psi to 30psi) ie (8.741 * 5 / 2..57).
Thanks for the math, Sir! I appreciate the effort.
Now I hear that there are stores who cater to people that enjoy making their own beer at home, and they have fair priced small co2 tanks. Any one has experience with those tanks?
No, he was asking about a compressor and tank, Straight air! Co2 with a tank would be by lbs. not Volume, and Co2 is a liquid in stored form not a gas, that's only in when it get into normal air, 14.2 lbs Baro. or less. . I have a 10 Gal Co2 that will fill my 35's twice and both my Daughter's Jeeps stock size with some left over. The same 10 Gal tank with air won't fill two tires back up...Wrong, you are confusing compressed Air with CO2. It is not just about speed, volume counts too, and CO2 has both. Watch the attached video, then look some up on your own....
Hey, thanks!I just like to understand things fully. Try Craigslist in your area for CO2 Tank, Bottle, Cylinder, etc... You are apt to find some deals there. I bought 5 20lb aluminum CO2 tanks for $100 off Craigslist.
Also, if you search Amazon for new 5lb CO2 tanks you'll find many. Also on Amazon you can find a fixed 150psi CO2 regulator for not much, just a little more and you'll be on the trail....
Good luck and let me know if I can help.
I watched that video and it is cool.I have what is call a spyder web, that you hook up to all four tires at the same time. You can deflate or inflate all four to the same psi. It has a regulator on it so you can set your pressure and leave it alone...You can make one, go to Trail Recon on Youtube, and Brad, has a video to walk you through steps to build one....
There is also the factor the CO2 will introduce moisture in to the tires which can cause rotting(from the condensate, you have seen the frosting right?). In Aviation & now some tire shops use Nitrogen. If I remember right it is less expensive then CO2, it is dry & the molecules are larger, thus taking longer to seep out then compressed air.That's true. And I'm surprised no one is talking about combining compressors with air tanks? It can really help mitigate CFM or Duty Cycle issues, depending on what the need is, and how the system is designed. Not magic, but this is the approach I am looking at for my own rig.
