Am I correct in saying that the AEV kit still utilizes the factory air box? If so I might be able to get away with adding one on w/o voiding my warranty.
It does utilize it. So the tube from the intake runs through the fender, then you remove the stock inlet that used to go into the fender. AEV provides you with a new inlet that is larger and connects to their intake. You rivet that new inlet onto the factory airbox.Am I correct in saying that the AEV kit still utilizes the factory air box? If so I might be able to get away with adding one on w/o voiding my warranty.
Yeah and in my case it isn't a Mopar issue. I am past the factory warranty but I have a lifetime drive train warranty through the dealership. It always muddies the water everytime I want to modify something. But thanks for the info.It does utilize it. So the tube from the intake runs through the fender, then you remove the stock inlet that used to go into the fender. AEV provides you with a new inlet that is larger and connects to their intake. You rivet that new inlet onto the factory airbox.
Whether that will void your warranty or not ¯\_(ツ)_/¯ - AEV works closely with Mopar, so it might not. A lot of their stuff is approved.
Thank you man. Hope to run even more in the fall here after we finish the rear bumper and modifications to the sliders. I've been pretty happy with the performance of this truck and just how capable the Power Wagon is. For the most part, other than my 35-inch tires, my suspension is currently 100% stock. These trucks rock.Absolutely sick! It is totally awesome that you ran those trails. Hell of a way to put FULLSIZE rigs on the map! Well done!
Benefactor
I'd love a diesel if we towed heavy. But since we don't, I chose a gasser. Also because I didn't have to do any mods to start wheeling really.We have chated on lots of topics, so I decided to look at your build. Love what you have done with your rig. Even better, you get it out to wheel. I have been playing with the idea of ordering an AEV, Prospector XL. I would want the Diesal. I have never wheeled a full size rig. I thought I would get you opinion, since you push yours hard.
It was disconnected. The AEV lift kit replaces the stock PW springs for stock 2500 springs. (See notes on AEV installation) - Considering the PW has a 20% softer spring rate and is already taller, that means you end up with reduced flex since you just put in a stiffer spring.Is it possible that he didn't take the time to disconnect the front swaybar on the AEV? Mine would lift a rear tire all the time before I removed one of the swaybar links.
Benefactor
Cool, you probably just saved me a s**t load of money. I will get the AEV bits that I like, and go with a different lift/suspension setup. Thanks for the heads up.I'd love a diesel if we towed heavy. But since we don't, I chose a gasser. Also because I didn't have to do any mods to start wheeling really.
They look freaking bad ass cool.
That's about the end of that. Do not expect performance or bang for a buck for that matter.
During this year's event, we had a member with a Prospector Power Wagon on 37's. It had problems flexing. His truck was the only one to tripod in several places. The front bumper on those trucks, absolutely beautiful. Possibly the best-designed bumper out there. But as for approach over the stock bumper. We measured it in person, it's 1 inch taller than the factory bumper. The lower portion of the tow hooks also keep digging into rocks, and on two occasions he couldn't tackle an approach without tearing up the bumper. So he had to go around the obstacle.
He managed to keep up and do almost everything we all did. But at the end of the day, I believe that AEV actually hurt their trucks with that spacer lift kit of theirs. They would have been better off designing springs. No matter what Dave at AEV claims about spring rates and stock ride characteristics, the stock Power Wagon has better flex.
That being said, what does it matter if it's on 40's ? LOL It will roll over most things. And like I said, he managed to do everything. Just a little more tippy and less stable than some of us.
But there are some other considerations. The member I mentioned basically paid twice as much as me for a tradesmen Power Wagon converted to a Prospector by AEV. I have a Laramie, paid less and have more options.
My truck doesn't look as cool I suppose... but I have leather heated cooled seat, premium sound, yada yada.
The Prospectors don't even come with lockers, and they even charge extra for diff protection.
If you want those looks, it's probably a better route to buy the bumper, hood and things from AEV rather than actually buying an overpriced Prospector. This way you can spend the savings on lockers and things.
They still look freaking awesome though, but I'd never buy one. Especially now that I've seen one in person on the trail for 6 days.
Like seriously, they look killer. I love the looks of those trucks. But once I start thinking practically... ¯\_(ツ)_/¯
You could probably just build a better truck.
Highly recommend Thuren Fab suspension. Their overland extreme kit looks unreal, even with their cheap overland shocks (although the Kings are obviously cooler)Cool, you probably just saved me a s**t load of money. I will get the AEV bits that I like, and go with a different lift/suspension setup. Thanks for the heads up.
