Another Subaru Build Thread
Terry Pickens
Evansville, WY, USA
Terry
Pickens
KJ7FTV
It will. The front will settle relatively quickly but unless you start making trips to Lowe’s for loads of pavers with your heavy friends the rear will take time.
I have to get some bags of sand to fill in a large hole in the backyard where I am removing a broken jacuzzi, so just the thing to help settle the rear out.
Reactions: Wawa Skittletits
Wawa Skittletits
Local Expert East Region USA
Expedition Master I
5,079
Wilkes-Barre, PA, USA
Drew
Hawley
WRBZ674
USN veteran
Well 10 minutes and it was off. Hoping for more articulation in the rear.
I've encouraged so many people to get of it I don't even recall if you were one of them haha. Its almost funny how easy it is to remove so I tell people you can always put it back on in a snap if they don't like it. 'Flex' is definitely helped a little bit but the big thing with a spring lift is the added droop.
Reactions: Terry Pickens
Terry Pickens
Evansville, WY, USA
Terry
Pickens
KJ7FTV
You were one who said remove it. It was a piece of cake, the hardest part was snaking it around the exhaust to get it out in one piece. Now what about a quick disconnect for the front ??????
Mine doesn't have large spring lift. King says with these springs it is only 3/8" in the front and 1/2" in the rear. We'll see after they set.
Wawa Skittletits
Expedition Master I
5,079
Drew
Hawley
WRBZ674
USN veteran
I've got some ideas for the front end links but a few things in the way until I get to it.
Terry Pickens
Evansville, WY, USA
Terry
Pickens
KJ7FTV
I looked at it today and the top bolt is easy to get to from under the fender on top of the tire. Now how to just hold it up out of the way. Undoing the one bolt on each side shouldn't take that long on the trail during airing down or up.
What kind of an easy inexpensive bracket can I come up with to test this idea ??????
Wawa Skittletits
Expedition Master I
5,079
Drew
Hawley
WRBZ674
USN veteran
To be honest its better to start with a new custom end link. The front sway bar is already not where it should be because of the lift so the end link needs to be shorter but its still not that simple. That shorter length can get a little tricky with the relief for the CV axle. Once you have the end link sorted it doesn't get any easier because attachment points for the disconnected sway bar are limited due to it being laced between the tie rod and axle/LCA. All that said I think it can be done.
Terry Pickens
Evansville, WY, USA
Terry
Pickens
KJ7FTV
Wanted to check in and see how the new springs are treating you. I'm in the market for some front springs to go with my rallitek oem overloads.
Sent from my Pixel using OB Talk mobile app
So far I really like them. Not to stiff unloaded and next week I will try them in an off road excursion. I'll report back after that.
Reactions: Rocky and WhatTheZo
rujero
Boston
Joseph
Ruggiero
Hey bud, nice build! I'm going to be building my rig with Subaru as well, either a Forester or Outback. I'm looking forward to seeing what else you do with this.
-r
Terry Pickens
Evansville, WY, USA
Terry
Pickens
KJ7FTV
Terry Pickens
Evansville, WY, USA
Terry
Pickens
KJ7FTV
Terry Pickens
Evansville, WY, USA
Terry
Pickens
KJ7FTV
max.grun
Turlock, California
KM6YSE
Terry Pickens
Evansville, WY, USA
Terry
Pickens
KJ7FTV
