Trail Blazer III
Trail Blazer III
I would weigh your vehicle and do your own testing, you may be heavier then the jeep.Wow really? That's a safe amount? I don't know just asking!
Tire manufacturers have application guides based on weight of vehicle and other factors. For example, I'm running D rated BFG TA KO2s on a 5th gen Explorer. Standard tires suggest 32 or 36, but based on weight and the D rated tires, guide said to go 44 psi on pavement. Ride is comfortable and works great. At low to mid 30s does really well on mud and snow and ice, and can still drive on highway, but after a while you see the temperature band around edge of tires from not being properly inflated.That on road psi is extremely high. I run my 35" BFG at around 30 psi on the street (12-15 on the trail). For on road pressures, check out the "chalk test". The ride will be so much smoother if you let even 5psi out of those Toyos, there is no need to run 40.
I completely agree with you on the chalk test, after a while you get really used to what you're running, rig and tire wise, and it becomes second nature.Tire manufacturers have application guides based on weight of vehicle and other factors. For example, I'm running D rated BFG TA KO2s on a 5th gen Explorer. Standard tires suggest 32 or 36, but based on weight and the D rated tires, guide said to go 44 psi on pavement. Ride is comfortable and works great. At low to mid 30s does really well on mud and snow and ice, and can still drive on highway, but after a while you see the temperature band around edge of tires from not being properly inflated.
Proper inflation for application and rotating on a good schedule are basic tire maintenance items that really help tires last. So far I have about 40k miles on these KO2s and they still have 7-9/32 tread left.
I had E rated ST Maxx on a FZJ80. The application guide for that use said 45 psi. More if I loaded it down a of course. 70 psi on those was just too much for the LC unless I had a LOT of weight. Same tire on a suburban tow rig ran 75 psi though.
The chalk test is a good way to make sure things are right as wellx especially if you can't find the application guide :)
Sent from my HTC6545LVW using OB Talk mobile app
Pathfinder II
Good article. Well worth a read!!!!Here's a little article we just updated for 2018 regarding the subject of airing down for both rigs and trailers:
Deflating for Overland Travel (2018)
I'm pretty sure Staun is out of business now. I think 4 Wheel Parts sells another brand which bought the rights from Staun and are about the same price as the originals.Nice article! thank you.
I have learned a little of this from my own research and experience, I've been airing down to 18-20 PSI on 265/75R16's using some generic Staun Knockoffs (The reviews on amazon were good, but I will be buying genuine Staun's as they leave a lot to be desired in my experience)
Trail Blazer III
