Appreciate it, Have also been looking to JKS they have some really well filled out setups. The lift is far enough down the road that I am not set on anything or really putting a lot of thought into it so I am sure when the time comes I will be picking everyone's brain! The other kicker to staying below 3 is that I am already going to be top heavy due to the RTT so driveability could come into play as well.I like your build plans except for your lift. Since you're looking to move up to 35's and are/were on the fence regarding a 2" lift over a 4" lift, let me give you some advice that might help make your decision.
First, you definitely don't need 4" of lift to clear 35's. 2" is plenty.
Second, if you go over 3" of lift, you will exceed the usable angle of your front driveshaft. That means that you are at the max limit of angle it can handle just at stock ride height. Do any wheeling and you're likely to destroy the CV joint. You will want to upgrade to a new front driveshaft using standard 1310 or 1350 u-joints to accommodate this. (Remember, this won't be needed if you keep it at 3" of lift or less.)
Third, it's really advisable to replace your front lower control arms with adjustable arms that can allow you to return your caster to the stock angle. This will keep nasty driveline vibrations out and keep your transfer case happy.
Fourth, you absolutely do not need to replace your stock track bars. They are plenty strong from the factory. You simply need to raise them up on the axle side using a relocation bracket. This will save you $$$.
My suggestion is to look at the Offroad Evolution Enforcer 3" lift kit. You can pick out your own shocks with this one. If you want any recommendations, let me know.
I love my T2 had a 100F for backup a while back but unloaded it sadlyNice! Glad to see another Fuji shooter here as well. I'm an XPro2 shooter with an X100t backup. Your build is coming along nicely.
