Hey man! So yes I started on JeepForum and took a 4 month break or so from the forum because I was locked out and busy with working, school and an internship. I graduated so I now have some free time as I’m pursuing a full time job.Howdy! Like your build thread. Did you come over from Jeep Forum? I could never reset my password after they reset them a few months back. So now this is my primary forum. And so many of the older tutorial threads were broken and useless because of photo bucket...
Anyways good to read your Jeep progress. I like the flush mount front LEDs. I may need to do that when it warms up. You just used your floodlight wires, yes? That's slick when you have a trimmed bumper to utilize the wiring and switch that's already there.
So have you figured out your death wobble for sure yet? Seems like you've really fought it. I'm alwasys a little fearful for my WJ but I figure I may as well not waste time fretting.
Cheers mate!
Sent from my SM-J320V using Tapatalk
Thanks. How do you use it, just dump it in with oil and you’re good?Try using Marvel Mystery Oil over Seafoam in the oil. I've used both and prefer MMO over the Seafoam for the price and function
Seafoam is good right before an oil change, but the MMO you add to the oil when you change it. I believe you add up to 20% of your normal oil capacity. for me, it was 1 qt MMO and 5 regular oil. You can also add it in the gas. It's been around for ages and I have zero complaints. It's actually helped with lifter tick.Thanks. How do you use it, just dump it in with oil and you’re good?
Cool good to know. I’m going to change the oil this weekend so can i put seafoam in now? I don’t have any strange noises at the moment but it has 183k on the clockSeafoam is good right before an oil change, but the MMO you add to the oil when you change it. I believe you add up to 20% of your normal oil capacity. for me, it was 1 qt MMO and 5 regular oil. You can also add it in the gas. It's been around for ages and I have zero complaints. It's actually helped with lifter tick.
Yeah, got ahead and add it and put some miles on it. When you change the oil, add MMO to the crankcase with the oil. I usually just buy the normal amount of oil and a quart of the MMO I add the MMO and the oil (minus 1qt) and run it. If it's low, add more oil. It'll help keep that engine running strong. I'm about to switch to the high mile Mobil1 syn oil. Heard good things on it's aid with older engines and the sealsCool good to know. I’m going to change the oil this weekend so can i put seafoam in now? I don’t have any strange noises at the moment but it has 183k on the clock
Good to hear. That’s what I’ve been putting in mine. I really like the penzoil high mileage but switched for this current oil changeYeah, got ahead and add it and put some miles on it. When you change the oil, add MMO to the crankcase with the oil. I usually just buy the normal amount of oil and a quart of the MMO I add the MMO and the oil (minus 1qt) and run it. If it's low, add more oil. It'll help keep that engine running strong. I'm about to switch to the high mile Mobil1 syn oil. Heard good things on it's aid with older engines and the seals
Yes to all of those upgrades. I'd run a second battery if I had room, but I also went with a deep cycle AGM battery that should have similar functionality like a dual setup would. I run my spare on my roof basket and use the spare wheel bay for storage. No drawer system yet but I still want access to the spare wheel bay and to be able to sleep in the back. I'm actually in the process (well, it's come to a halt) of making my awning. It's basic so far but I want to have a more rigid setup. Good luck!After reading around on this forum and watching videos I’ve come up with a few things I would like for my build that’ll make the jeep more dependent.
Air compressor
Winch
Dual batteries
Storage drawers
Tire carrier with storage
Snorkel?
I’d also like to make the awning, get a fire extinguisher, and cooking supplies like the gas stove. We usually cook by fire but we’ve had times where it rains and you can’t build one.
Thanks for the idea. I suppose I could do an AGM battery. My last wrangler had one and it worked well with the winch and extra lights. I enjoy wheeling (rocks, mud, and sand here in NC) so I’m trying to make one rig do it all. Currently I keep a bunch of tools and recovery gear in the tire well now. That would be relocated to the drawer system and I could then do a tank tuck. How did you do your awning?Yes to all of those upgrades. I'd run a second battery if I had room, but I also went with a deep cycle AGM battery that should have similar functionality like a dual setup would. I run my spare on my roof basket and use the spare wheel bay for storage. No drawer system yet but I still want access to the spare wheel bay and to be able to sleep in the back. I'm actually in the process (well, it's come to a halt) of making my awning. It's basic so far but I want to have a more rigid setup. Good luck!
Thank you. They’re always a work in progress lolGood looking rig love the build
Yeah I know. Our lkq yard is full of them. Fortunately I know the guy that owned it took care of it. He had receipts for everything he did to it including diff fluid and oil changes.nice wj I have been on the fence on one for a while. The 4.7 scares me you see so many of the blown up because of lack of maintenance.
