i always thought the more power, the less you have to waitPower to wait ratio will cause most trucks to sit and spin in the snow.
Good catch. That was sharp witted enough I will not be editing my post.i always thought the more power, the less you have to wait
If you shouldn't brake downhill what should you do instead?I run 2wd 90% of my offroad travels. 4 hi is for when the tires start to spin. I hate the thought of chunking out 2 grand in tires. I will also use it anytime there is snow. Power to wait ratio will cause most trucks to sit and spin in the snow. 4 low is for when the engine starts to bog down, if I need to go slower than 4 high due to rough terrain, or when 1st or 2nd gear doesn’t want to hold me back on a down hill. I absolutely hate when people ride the brakes going down hill. When you overheat your brakes and start to experience brake fade, it can cause some sketchy scenarios on the trail. It’s actually kind of interesting to see when others will decide to lock in the t-case and why. I know a guy that uses 4hi anytime he leaves the pavement.
Actually when I read the part about going 60 I imagined he meant off-road.60 mph in low?????? are you kidding us??
maybe YOU should go study your owners manual.
i am not aware of any t-case by any manufactor that would give a green light to go anywhere near 60 in 4lo. if you want to grenade a t-case, just follow this dumb advice....
and unless you have diff aids, 100 hp will go to one tire and in 4 wd 50 hp would only go to 2 tires, which is about 90% of 4x4's out there.
to drive a part time case on hard roads is a sure way to destroy all your 4x4 parts.
are you even aware why you shouldn't drive on hard roads? cause your advice sure says otherwise.
your front tire rpm's combined are always greater than your rear tire rpm's combined. as the transfer case is putting equal torque to both axles, it is trying to keep the rpm's the same while the front tires are trying to rotate faster. this is why you need slip under your tires, to relive the stress. but if you want to keep driving on hard roads in 4by, just make sure to post pics when your t-case chain breaks, your output shaft splits, your u-joints explode, your diffs drop their guts all over the road......
jeebus...from the guy who thinks a locker can send 100% of your power to one wheel.....
Down steep hills, you should select 4L. Engine braking will do most of the work. And with lockers, you'll erode the trail far less.If you shouldn't brake downhill what should you do instead?
In a broad sense offroad yes, but I see too many people thinking that their bald tires on a 4x4 will stop them on an icy road when they slam on the brakes lol.Negating the old wives tale: "4WD won't help you stop.''
More snow the better. A lot of people seem to substitute 4x4 for common sense is basically what I'm getting at. I'm in the snowmelt too lol. Canadian side lolDon't run bald tires. 4wd works better on the street as well.
41 years in the snow belt.
It definitely depends on your system. Clearly a Subaru is AWD all the time. A newer GMC or Chevy truck with 4x4 has a dial which includes an Auto setting. This is essentially AWD, however, you should not run in Auto in a GM truck as a regular practice. The 4x4 clutch packs wear out faster than they should. In my GMC, I use Auto (like AWD in a Subaru) for wet conditions, light snow, like when the blacktop is visible in my tracks after riding through rain, sleet, *wet snow!* and the like. Full snow cover generally garners the 4 hi setting for meIt depends on your 4wd system. As a general rule you should only run AWD (all wheel drive) on pavement in any conditions other than full snow cover.
You're looking for black and white answers to a grey question. Go out and experiment, might not hurt to take a 4x4 101 class either.Hi, I'm new to overlanding, and off-roading.
I've read that you should never engage 4WD unless you're in a low traction situation, otherwise you'll mess up a lot of things.
So is there an exact minimum on how, for example, wet the road has to be?
Exactly, on forestry roads, but it really makes no difference, I drive the highway often in 4H at 60MPH, on most days there is a mix of snow, slush, dry pavement.Actually when I read the part about going 60 I imagined he meant off-road.
