What's your campfire in fire season or no campfire areas?
Do you belive carrying a portable campfire in needed?
  • Yes. Expectially in campfire restricted areas.
    Votes: 13 54.2%
  • Nope. Just suck it up and put more clothing on.
    Votes: 11 45.8%
  • Total voters
    24
Chandler, AZ
Jake
McCurdy
We really like our Outland Bowl, quick and easy!
How is the quality? I noticed the Outland Bowl is bigger than both the Red campfires and $50 cheaper than the Little Red Campfire and $76 cheaper than the Big Red Campfire.
Quality is excellent in the camco product other than the jenky latches. The outland bowl is nice but will likely be is 10lbs heavier and messier 4 offroad with the lava rocks. My parents have one and it works well for their rv lifestyle. Camco is just more overland friendly IMHO.
Reactions: Viking1204
NMBruce
Pagosa Springs, CO, USA
Bruce
Cooper
KE0NBD
U.S. Air Force
We love our Little Red Campfire. Way lighter and more self contained than a lava rock fire. More realistic and easily roof mountable:
I have one of these and also carry this 80,000 BTU Propane Convection Heater, the second heater is great for colder weather. We use it also in the mornings when it’s not in the best interest to start a fire if your leaving in a couple of hours.
Living in the west, no fires are becoming more and more common.
Bpjr07
Baldwin Park, CA, USA
Ramiro
Vargas
I also have the little camco campire, bought it because of the cali fire season. Replaced the fake ceramic logs with lava rocks to hold the heat, feels more effecient.
Reactions: NMBruce
Jk.Overland
Cape May, New Jersey, United States
Joe
Hennessy
US Coast Guard
I searched the threads to see what folks used when campfires were not permitted. Couldn't find a thread. So as we come closer to spring and possible fire restrictions in the west. It would be interesting to see what OB'ers use on the trail.
After seeing a friends Unimog outfitted with a 20 foot attached hose from their propane source to a portable campfire, I knew I needed one but in a smaller version that would not take up much space in the 4Runner.
This is the unit I went with.....View attachment 48463
This unit with a half size propane cylinder worked like a champ. It packs up in its own pouch and takes up limited space.
Alot of places I have been did not allow camp fires or gathering materials for fires. My go to item for when I want a fire but cant have a fire pit or gather materials is this. It is a fire in a can. Lasts for hours, easy to put out with the lid, smells good, and puts off enough heat that when my brother and I were out camping last winter we were warm. (we live in the south so our winter is vastly different than yall in the north)
Fire in a Can
Reactions: KAIONE
Downs
Hunt County Texas
Joshua
Downs
KK6RBI / WQYH678
USMC 03-16, FIRE/EMS
I just don't have one. But looking at the LAVABOX looks promising but, no way I'm paying 200 dollars just to have a camp fire, I've got some 50cal cans floating around here I'll see what I can figure out.
Reactions: Bpjr07
Bpjr07
Ramiro
Vargas
Yup, just built one out of a 50 cal. Box it was too big, nice that it will hold the hose inside.
Build one with 5.56 box and its perfect. 1/2" ridgid pipe drill out some holes. Some home depot pieces and 7$ propane valve and hose.
Few lava rocks
tjZ06
Las Vegas/Palo Alto
mynameisntallowed
Adams
I have both this, and the "Big Red Campfire." Love 'em both. The way they pack up is perfect for throwing in the rig. FWIW, they both have the same size fire ring, IIRC, so actual flame/heat/propane consumption is the same.
-TJ
DRAX
Bend, OR, USA
Hogan
Whittall
W9DRX
This is the fire pit I have was bought off of Overland bound. Absolutely amazing easy to clean and can also be used as stove
Problem is that doesn't get around fire bans/restrictions during fire season, which is what the OP was asking about. Those are great portable fire pits but since it still burns wood and releases embers it's still a danger and can't be used during fire bans.
Reactions: Tundracamper
Tundracamper
Tuscaloosa, Alabama, USA
Shepard
Same here. Got one on order. Can’t wait to see what this little compact option will do.
So, just had my first official outing with the LavaBox after playing with it at home. At this point, I’m just ehh about it. The flame seems to be on the sooty side for propane. Perhaps the burner is too far down in the box for the right fuel ratio. Not sure.
While it will burn over 90 minutes on a 1 lb bottle. It does start struggling after 30-40 minutes in timid weather or after about 10 minutes in real cold weather. I cranked it up all the way in 25F weather this AM and the flame shown in the photo is all it would do after about 10 minutes. Shaking the bottle definitely made the flame bigger, until you stop shaking. Maybe I need to try it without the shutoff valve in line. I’m thinking a 5 lb bottle may work better in the cold temps.
I also noticed that the burner is only supported at the inlet. While the rocks are very light, I’m still concerned it might bend over time (it’s already at a slight angle).
I plan to play with it more as it’s very compact. Still, not what I was expecting in terms of ready to go out of the box - especially for the price.
Tundracamper
Shepard
Did some more testing. The LB on a 1 lb bottle with an adapter and a valve ran really good in 21F temps for about 10 minutes then throttled back, way back. So, I put the tank in a bucket of lake water and the flame came to life, again for about 10 minutes. Then, it was like a pilot light. Funny thing is, the shutoff valve wouldn’t cut off on the adapter. I think I have some freezing in the adapter.
Can 5 lb bottles put out propane at a higher rate than 1 lb bottles?
DRAX
Bend, OR, USA
Hogan
Whittall
W9DRX
Ultimately, you need to determine what is freezing and causing your low flow problem. If the regulator is freezing then the higher flow from a 5LB tank won't matter (yes, they can have a higher flow rate due to the larger valve and orifice). If the problem is that the "high" flow rate from the 1LB bottle is causing the bottle temp to drop so much that there's no pressure then the 5LB tank would work much better, at least until that tank started to freeze. :D
