what PSI do you run on trails?
06tacodude
Traveler II
1,653
Morgan Hill, California, United States
Alarcon
KN6GLP
I'm now running 255/75/17 BG KO2s C-Load rated tires on the Tacoma.
On the HWY I'm usually 36psi Front and 34psi Rear.
On fire roads, I typically drop down to 22~24psi. If it gets rougher or I need more traction due to loose gravel or sand, or if it's crawling over rocks, then I'm down to 20~22psi. I have gone down to 18psi but only if needed. I find going over mix terrains I'm good with 22~24psi.
At the sand dunes I dropped down to 16psi with no issues.
702FJC
Las Vegas
Joe
R
Regarding the Wildpeaks, I'm starting to see a little chunking and lots of thin slices in the tread. I'm not sure how many miles I have on them but likely under 10k and they see a lot of trail abuse. These small slices will most likely lead to chunking. That makes me suspect I'll have to swap them out long before the tread wears down normally.
I wound up going with the P rated AT3W and like what I see so far. Can't wait till we get snow up in our local mountains, that's where tthese tires will really shine I think.
Reactions: JCWages
gothnate
Pathfinder II
603
Franklin, NC, USA
Nathan
Crawford
I have
LT285/70R17 - 121/118R E RWL BFG KO2s. The specs on my tires say 80 psi maximum for on road, what should I run aired down on a trail?
Bama_Kiwi
Christchurch, New Zealand
Ryan
Frank
275/65R18 Cooper Discoverer STT Pro
36PSI on road, 18PSI off. Really stiff sidewall on these, though. Hardly any 'pooch' at all - haven't tempted fate by going any lower, but 18PSI seems OK so far.
JCWages
Grass Valley, CA, USA
Wages
I have
On a T4R most people run 35 to 40spi on the street and 15 to 20psi offroad depending on conditions and the weight of their build. You do not want to run anywhere close to 80psi. Ever!
JCWages
Wages
I think you'll like them. Obviously there are some snow conditions where nothing short of a studded tire will provide traction but in most cases they work quite well. I still recommend running in 4wd when you can't see pavement.
Reactions: 702FJC
JCWages
Wages
These are 10-ply tires, not the normal 6-ply.
BFGoodrich All-Terrain T/A KO2 285/70R17
I know. :) I have friends who run them and I lurk the T4R and TacomaWorld forums. I also run 10ply tires in that size as well and my truck is probably heavier than your T4R. Anything above 40psi starts to ride rough and by 50psi it feels like the truck is falling apart.
If in doubt do the chalk test.
wvjeeper
WV
Derek
T
K8CD
I run my 35's at 15-20 PSI on the trail. Usually 30-35 on road.
Reactions: JCWages
gothnate
Pathfinder II
603
Franklin, NC, USA
Nathan
Crawford
So, you're saying 40 psi on the trail is good for these?
Dualsportrider
DFW
Rizzo
NA
35 psi in a P rated tire can handle more weight then 35 psi in a load E tire. So you have to put more air in the load e for the same load.
Reactions: 702FJC
Nomad164
Rockingham, Western Australia, Australia
Karl
Fehlauer
Army
Here in Australia the terrain differs from state to state, region to region etc so there is no one specific (or correct) tyre pressure to run - basically you need to determine that at the time and make the necessary adjustments.
I run Coopers ST Maxx 265/75 R16 ATs and my go to pressures to start with are:
1. Firm beach sand - 15 PSI;
2. Soft beach sand - 10 PSI;
3. Dry gravel / hard dirt road - 25 PSI
4. Wet gravel / dirt road - 20 PSI
5. Dry red dirt (outback country) - 25 PSI
6. Wet red dirt (outback country) - park and wait until its dry :grinning:; and
7. Mud - 18 PSI
But as I said, these are just a starting guide and I will adjust accordingly depending on my load or whether I am towing etc.
Karl
Dualsportrider
DFW
Rizzo
NA
Mind........blown!
For stock fj tire
32 psi. 2414 lbs
For LT tire
35 psi 1890 lb
50 psi 2470 lb
80 psi 3195 lb
Reactions: 702FJC
JCWages
Wages
For stock fj tire
32 psi. 2414 lbs
For LT tire
35 psi 1890 lb
50 psi 2470 lb
80 psi 3195 lb
Practically speaking most people that change to an LT tire also upsize so air volume increases and you are also no longer subject to the 10% reduction in load capacity as when using a P-metric (SL) tire on a light truck or SUV. So yes, SL tires require less pressure to carry a similar load than an equivilent tire in LT build but that doesn't automatically mean you have to run 80psi in your LT tire. When crunching the numbers I only need to run approx. 40psi in my LT285s to match my OEM tire load capacity. In practice the LT285 at 40psi feels WAY more stable with less sidewall flex than the OEM tire at 35psi with the same load. The chalk test will show that 40psi is a little overinflated for my truck, however.
Euro-metric and P-metric tire sizes were originally designed for cars and station wagons; however, they have also been used for light truck applications because most vans, pickup trucks, crossovers and SUVs are used to carry passengers, not cargo. Additionally, most of the new light trucks being produced today are equipped with Euro- or P-metric sized tires because they offer lighter weight, lower rolling resistance and less aggressive tread designs (which makes them better riding, more fuel efficient and less noisy) than typical heavy-duty tires.
However, there is an idiosyncrasy governing the use of Euro-metric and P-metric sized tires on vans, pickup trucks, crossovers and SUVs because these vehicles have a higher center of gravity and greater probability of being overloaded than passenger cars. In order to accommodate this, vehicle engineers are required to specify Euro- or P-metric sized tires rated to carry 10% more weight than would be required if they were used on a passenger car. This is the equivalent of taking the tire's load capacity branded on its sidewall and dividing it by 1.1. For example, a Euro- or P-metric tire designated to carry 2,000 pounds on a car is restricted to carrying 1,818 pounds when used on a van, pickup truck, crossover and SUV. This size selection practice provides the vehicle manufacturer with the appropriate tire load capacity.
Reactions: 702FJC
Dualsportrider
DFW
Rizzo
NA
I'd be afraid I'd bounce off the highway if I put 80 PSI
Reactions: JCWages
