What is YOUR ultimate overland setup, and why?
OTH Overland
Local Expert Washington, USA
Trail Blazer III
4,847
Camano Island, WA, USA
Dave
Ballard
N7XQP
Fire/EMS/SAR
Ram 3500 Diesel Crew cab with 35” tires and extended range fuel tank and truck bed topper
- Fuel efficiency is on par with most smaller trucks that are loaded with all the typical overland stuff.
- Relatively simple solid front axle
- Tons of power for extended highway trips through the mountains
- Never run out of cargo carrying capacity
- Comfortable enough for 4 adults (only two of us with a small dog)
- Capable enough for mild trails
- Replacement parts are as close as the nearest parts store
- Could sleep comfortably in the bed of the truck
My 3500 always beats out my wrangler mileage wise and has power to spare. and its 5k lbs heavier . does suffer on tight trails and has a horrible breakover angle being a mega cab model, it will lose its dually bed in exchange for a habitat one day soon I hope, and then it will become our winter travel vehicle as we will be able to sleep inside an insulated box instead of a tent.. Figure between the two of them we will have our "Ultimate Overland fleet" depending on the nature of the adventure.
reaver
Caldwell, ID, USA
Brian
McGahuey
GMRS WRMV941
This is why I'm a big fan of the modular setup. The trailer goes when the family goes, or if I were doing a very long trip (which I haven't done yet). If it just me, or my daughter and I, the trailer usually stays home, and we take just the X. I have independent water systems (5 gallons in the X, 10.6 gallons in the trailer) a full kitchen in each (single burner stove in the X, dual burner stove in the trailer). Chairs that live in each setup (compact chairs in the X for my daughter and I, and bigger, comfier chairs for the whole family in the trailer).
DintDobbs
Daniel &
the Vulture
@OTH Overland @reaver This! There is no one ultimate vehicle for every task (taking us back to @RichieFromBoston's "ultimate" thread), but rather, the ultimate collection of purpose-built vehicles and add-ons for each task. More options are always better. Best option would probably be a built full-size rig for base camping and towing a smaller jeep or sandrail/OHV for scouting around, storing your interchangeable gear at the base rig (think two sets of 5 tires, one M/T, one sand paddle or whatever). The ULTIMATE ultimate setup.
Dilldog
Spokane, WA.
Dillon
Wilke
KJ7LVO/ WRQL275
USAF
I have thought about this a lot over the years...
Square body Suburban MUST have barn doors
4BT Cummins with the VE injection pump (the rotary VE pumps tend to be tougher, but make less power) with +25 hp injectors
GM TH400 transmission
NP203 range box with an NP205 that has been twin sticked
1ton early GM axles with 3.73 gears ( king pin Dana 60 and the GM/ AAM 10.5" "14bolt" both with automatic style lockers)
cutting brakes on rear axle
rear axle disc brake conversion
35" A/T tires
rocker rails, front and rear bumpers that have wrap around segments to protect the body with hollow fully welded construction to be used as air tanks, brush guard on front
Warn 8274 winch on a multi mount plate and wired so it can be moved from front to rear, or removed and secured
2 simple light bars, one forward facing and one rearward facing
single cylinder Bendix air compressor with a manual over ride for the unloader valve
dual battery set up utilizing group 31 batteries
From there it would just be camp equipment.
For the why, I have always loved Suburbans with barn doors. Being a diesel mechanic by trade it makes sense to swap one in. I would want a 4BT as opposed to the 6BT to get slightly better mileage while maintaining lighter weight, easy serviceability and durability. I would want a mechanical 8 valve with the VE rotary pump for better durability and to open my fuel options up (the VE pumps will handle much dirtier fuel than the P7100s so running waste oil is easy peasy). I would want the old school 3 speed auto for simplicity. The 203 transfer case had a removable gear reduction box and it is commonly adapted to the front of the cast iron gear driven 205 transfer case to get an additional 3:1 gear reduction. So total low range reduction would be 6:1. The 205 would be twin sticked so I can select front or rear axle drive seperately, this is important for using cutting brakes (kick the rear axle out lock one rear tire, kick the front end in and the truck will pivot on one wheel). I would need the greater gear reduction to allow me to lug the 'burb around off road with a 150ish HP diesel.
I would want an 8274 winch because they are the only US made winch that Warn makes anymore and I have seen them work harder than some 12K rated winches, they are also very easily serviced and replacement parts can be had at Napa. Also the design is 70 years old now, its lasted that long for a reason.
For on board air I would run a small truck style air compressor. This would bolt directly onto the little Cummins and be gear driven. I would simply rig in a manual over ride on the compressor unloading valve so it wouldnt be compressing air until I flipped the switch. For air tanks I would use the hollow cavities in the body protection.
