What is your next mechanical upgrade or repair?
davis31052
Awendaw, South Carolina, United States
Eddie
Davis
U.S. Marines
UGH!!! As of right now, Entire cooling system overhaul including new water pump, all hoses, coolant, and repaired radiator overflow nipple.
BTW,if anyone has a broken nipple on the top left corner, I found a replacement and came up with a fix for it. Might save you a couple hundred.
Front crank seal, oil change, transmission service and cleaning/sealing the XYZ switch for the "M" & "S" lights and trans going into limp mode.
After that, replace the condenser fan motor and sort out the A/C system. That'll keep me busy for the next month since I my only time to work on it is Mondays. 2003 LR Discovery II
crit_pw
Silt, Colorado
Next upgrade for me is Thuren Springs and KING custom valved shocks along with Thuren track bars front and rear.
