I put this here, instead of recovery due to having a larger impact and viewership, along with a cautionary tale.:
So I decided to do a upgrade that I had put off due to cost. When I had my 17.5 K winch installed, I found out that because of the size, the winch hook had to be larger than standard. Because of this, you could not spool the cable in and have the hook be put flush between the rollers. This was a problem as I used the ARB plate slot for a aux plate, and used a roller fair-lead license plate holder for my State issued one. With the clips snapped over the rollers, there was not enough clearance for the hook. The solution was the Factor 55 flat link. However the price caused me pause, as I did not want to put that much out lay on a convenience item, even though I recognized the safety aspect of a 'closed-link' attachment. i had considered the Smittybilt thimble but it had gone up in price from about $45 to $79 in less than a year, but it would not have addressed the clearance problem I faced. I came across this product, Which is a clone of the Factor 55 flat- link. It is a nice copy and has the rated strength needed for a 17K rope cable. Offered by MZS tuning at $49.99, it was at a price point that I could not pass up on at Amazon. This product checks the boxes for my clearance issue and having a CLOSED LOOP system for my winch. It will allow both front plates mounted at the same time and keep the police happy.
Story:
Years ago while driving along a area where there had been a off-road race the week-end before, I came across a buried F-150 4x4 that had driven into an area where the dirt had been stirred into talc like fine powder. They had been stuck for many hours in 115' heat with little water during high summer. No shovel, No traction boards, and no place anywhere to attach their winch to. The trucks owner had installed a closed link thimble inplace of the hook,........BUT......had not bothered to bring a shackle/D-ring with him to attach to another recovery device. Lucky for him or unlucky depending on your view, he had synthetic line. So to use the winch as a tow line/recovery line, we cut the thimble off, so we could tie a knot to my D-ring to pull him out, then cut some more line to detach the knot. Motto to the story,..............bring the additional recovery gear for any upgrades you plan, and bring necessary water for unforeseen stuck situations, as They had been stuck for hours and practically threw themselves in front of my vehicle to get my attention. No one had come their way in the hours they had been stuck.
