SVgarage
Livermore, California
Eddy
Louis
KO6BOH
Is that a side fold out one? It looks like a good use of space!
Yes, it opens to the passenger side only. I have an ARB awning that I'm going to mount on the driver side. It's the iKamper Skycamp Mini 2.0 and it'll sleep 2 adults and a dog- perfect for my application! The full-size Skycamp would be too much for a 2-door JK. With the Mini, I still have room to mount extra gas or traction boards in front of it. This is last year's model, as the 3.0 is out now, but there's not a dramatic difference in upgrades, so I figured I would take the $900 savings. I considered the Tuff Stuff Alpha 2 (which is also on sale), but in the end, I just bit the bullet and went iKamper. No one can dispute their quality.
Reactions: Shahn
Rubicajon
Creator III
4,572
Panama City Beach, FL, USA
Rubi
cajon
KG5VLS
Navy Seabee’s
First pic was 34x10.50 bfg mud terrain. Technically it has 0 inch of lift. With that said I did put jku rubicon front springs in the front and I believe they are 19s and I have 56s in the rear now and a new set of jku rubicon 60s to install this weekend.
I did the usual spacers for the wheels and did not cut the body but hammered the seam over flat. The only rub is on the front passenger side at full lock.
Reactions: Shahn and AggieOE
AggieOE
Pearland, Texas, USA
Nathan
NWK
Finally put on the 37s
Always good to see what's capable without going crazy high on lift. Nice work! Still looks subtle and clean.
After a four month wait, the T4R finally got its new rear bumper. The departure angle has increased significantly.
That looks great! Is it custom? Love the low-profile look.
Reactions: Rubicajon
Ocean_Ranger
Santa Barbara, CA, USA
Sean
Pickton
N6SRP (GMRS WROQ518)
The low-profile look is what pulled me in. It is not custom, Nguyen Works is the name of the company. The departure angle on my rig increased from 27 degrees to almost 40 degrees.
Call_me_Tom
San Joaquin County, California, United States
Tom
K9er
USMC Ret
I finally had some time to get this RTT installed on the Jeep. I did the install alone and it was not easy! Can't wait to get into the wild to try it out!View attachment 255702
It took me and my two teenage sons to lift my RTT into place, I’ve no idea how you did it. One thing is for sure, after all of the effort of getting it mounted I’m not taking it off.
  • Haha
Reactions: Shahn and SVgarage
CR-Venturer
Ardrossan, AB, Canada
Jas
Spr
First, took the rig for a little explore yesterday of a section (160 acres) of crown land near my house, and found an epic little camp spot.
Then today, I installed the new Fire Ring cable I got for my CB radio setup. WAY better with the low profile mount, and the SWR is perfect across the board! 1.5 on channels 1 and 40 and 1 on 19. I am very stoked.
slowlane
Wisconsin USA
Tim
Bender
Did a little maintenance on the '66 VW in preparation for my trip to Kansas in a week. Adjusted the valves, filed and gapped the points, cleaned the contacts in the distributor cap, and adjusted the timing. Still need to change the oil and set up the sleeping platform and it should be good to go.
Distributor apart to clean and adjust points and clean contacts on cap and rotor.
Setting the timing with a test light. The timing on these engines (well with stock parts anyway) is set statically. Turn the engine until the 10 degree BTDC mark on the crank pulley lines up with the case seam, then turn the distributor until the points just open (test light illuminates), then tighten distributor clamp and test rotate a couple times to make sure the adjustment is holding.
Valve cover removed. Turn each cylinder to TDC and adjust valves to .006".
SVgarage
Eddy
Louis
KO6BOH
I had to use my hard top hoist that was already mounted in the garage. I let the strings and straps out as long as they could go in order to lift the tent from the garage floor, but then I found that the line would only let me raise the tent about 4 feet off the ground, so I had to rest it on my BD Workmate and reset the straps again! That was just enough to get it high enough to drive the Jeep under it. It was a project indeed!
JaredThomsen
Concord, Contra Costa County, California, United States
Jared
Thomsen
After getting my rig almost a year ago I finally took the hardtop off my JKR today for the first time - and I’m digging it! Bimini top coming in tomorrow to help provide a little sun protection.
roots66
Local Expert, Texas USA
Weir, TX, USA
Roots
GMRS: WSGB862
USAF
Took the camper shell off, put the bed cover back on, and gave it a proper cleaning. Wife spent 2 hours detailing the inside and actually got the dog hair out. I spent $25 at the car wash...then came home washed it correctly.
