I went out and tested the new bump stops, huge improvement!
Do you find you have enough thickness in the rotors if you just change pads or how often do you change those? On my LR4 it seems like you go through rotor material pretty fast, so I change them out at the same time. Same with the pad sensor, it gets so brittle that it just needs replaced.Replaced the rear brake pads, changed the oil and replaced front wiper blades on Brutus today.![]()
Sometimes the rotors are thick enough but you run the risk of brake noise. I am willing to take that chance this time. The rotors were thick enough on this round. I usually recommend rotor replacement though. They can definitely not be resurfaced.Do you find you have enough thickness in the rotors if you just change pads or how often do you change those? On my LR4 it seems like you go through rotor material pretty fast, so I change them out at the same time. Same with the pad sensor, it gets so brittle that it just needs replaced.
Pathfinder II
It was. I should have got a pic of the stuff that stopped us.Looks like a fun road!
