Expedition Master III
Can you send me a link to the Canadian channels. I want to update the OLB list. Kent@overlandbound.comI found out gmrs is NOT the same as Canadian road channels.
OB could apply for its own simplex frequency. You would own it so to speak. I think if you do that users won’t require a HAM license but the FCC could tell you about that. I believe the cost is around $150.OK guys, here it is. OLB Comms Channels:
- Ham 146.46
- GMRS 15
- CB 16
Good info, we are working on something right now! so standby more to come.OB could apply for its own simplex frequency. You would own it so to speak. I think if you do that users won’t require a HAM license but the FCC could tell you about that. I believe the cost is around $150.
One thing with 146.46 that is incredibly annoying is people carrying on long conversations. Find people on that channel and move on to something else. This is why dual band radios are so nice.
My 1 Cent.
@brienOB could apply for its own simplex frequency. You would own it so to speak. I think if you do that users won’t require a HAM license but the FCC could tell you about that. I believe the cost is around $150.
My 1 Cent.
Sent you an emailCan you send me a link to the Canadian channels. I want to update the OLB list. Kent@overlandbound.com
146.46 (and especially 146.52, the national calling frequency) are generally accepted "calling frequencies" the whole point of these frequencies is to make initial contact to see who's out there. Using a calling frequency is not a bad idea, in fact, it is the accepted best practice among hams to make initial contact. Once contact has been made, operators should (again, this is best practice) agree upon a NEW simplex frequency, and then switch over (QSY). Every licensed amateur radio operator, in the U.S. at least, should hopefully understand this behavior, especially considering they have taken a test who's question pool asks specifically about this situation, if i am remembering correctly.Well my final rebuttal would be using 146.46 is a bad idea
Here's a link to a video that helped me get my baofeng programmed.146.46 (and especially 146.52, the national calling frequency) are generally accepted "calling frequencies" the whole point of these frequencies is to make initial contact to see who's out there. Using a calling frequency is not a bad idea, in fact, it is the accepted best practice among hams to make initial contact. Once contact has been made, operators should (again, this is best practice) agree upon a NEW simplex frequency, and then switch over (QSY). Every licensed amateur radio operator, in the U.S. at least, should hopefully understand this behavior, especially considering they have taken a test who's question pool asks specifically about this situation, if i am remembering correctly.
At risk of continuing to sound like a broken record: the recommendation to use 146.46 for "OB Comms" is ONLY as a calling frequency, as, again, it is the generally accepted off-road national calling frequency. I'll point out that i've also called this out in the official OB comms guide:
Once contact has been made, operators should (again, this is best practice) agree upon a NEW simplex frequency, and then switch over.
This frequency is the generally accepted off-road calling frequency. Amateur operator etiquette means that this common calling frequency should be used primarily for initial contact. Any extended conversations or group use, like communication while on a trip or a trail run, should likely be moved to a different nearby frequency.
I would like to address your two other great points, which i'm glad you brought up.
1) Unlicensed operators - The amateur bands are self-policed by amateur operators. We should always reject communication with unlicensed operators, in fact, the FCC requires it for all licensed operators. Amateur operators risk having their license revoked if they communicate with unlicensed hams. If these unlicensed operators are known, for example people in our group run, we should be telling them that they absolutely cannot operate, and at the same time giving them advice/support for getting them licensed. We are also working behind the scenes towards some training programs to help more Overland Bound members get licensed as well.
I'll also point out that if an unlicensed operator is very very persistent in their "but nobody is gonna care if i do it for this one trip are they?" routine, it is probably a sign that they just really want to be a part of the comms, and it might be a good diplomatic decision to select a different radio type that they can us, like FRS, CB, or if they are licensed for it, GMRS. Of note, this is why we've selected GMRS 15 as the official FRS/GMRS channel, as the channels between the two services overlap. GMRS users can blast up to 50W on channel 15, FRS can TX up to 2W. I always have a couple of extra FRS radios in the rig so that if I decided to use licensed GMRS as the main comms, i can give out the unlicensed FRS radios to the unlicensed operators so they can still participate.
2) Programming radios, especially the popular Chinese radios. Before i get to the meat of this, i want to first say that as far as simplex goes, on all HTs I've ever used (Baofeng, Kenwood, Yaesu) switching to a simplex frequency is basically as easy as punching in the desired frequency. For simplex there is no need for programming in offsets, ctcss tones, pl tones, etc. So for simplex uses, no manual programming knowledge is generally required. If a group leader has decided to use ham radio as the primary communication for a trip, they should be sure that 1) everybody using it is licensed, and 2) they (the run leader) will be able to help people punch in frequencies if help is requested. If a group leader is unable to do both of those, they should not select ham as the primary communication.
Now, as far as programming and using repeaters (which required programming), i've been thinking about this a lot lately, especially as i talk to more and more new hams. We all know that the test doesn't help teach you how to actually USE radios, and this is probably the biggest gripe i hear from new hams, and it was definitely the biggest issue i had when i was first licensed - I had my license, but i still had no idea how to use even the simplest radio, let alone program it. To address this, i've been thinking about putting together two things, one is a guide that's like "Ok, I got my license, now what?" That will go over some basic radio usage, radio etiquette, common practices, common terminology/jargon/shorthand, and more importantly, how to find local clubs/meetings/hams to learn from. The second thing is a guide to repeaters and programming baofengs, both manually, and by using a computer/CHIRP. I'm thinking of doing the first iteration of this programming training as a livestream or webinar or something, where anybody in the OB community would be able to join via the internet and interact via live chat in real time to ask questions and such. I've only just started putting this together, so it's not likely to happen until at least December. Due to the holidays I may wait until January so that it will be easier for people to make the time to join in.
I'm with you on keeping the barrier to entry for our hobby low.So new member here, never been on a ride with anyone else and would love to group up and do some more adventurous trails. I know we'll need to communicate during those trips and am keenly interested in the decisions being driven here. Outside of cell phones I don't own any radios at at right now.
My only experience with radio is in the army as an FM operator (31K). I have no fear of radios or learning and was even proficient in morse back in the day. I have learned and forgotten the details of radio wave prolongation, why matching units are required and taking licensing tests.That being said I have zero interest in learning virtually anything about radios and the whys and wherefores of them.
For safety you can't beat the simplicity and reliability of devices like the Garmin in reach communication systems. The can also be used in and out of the vehicle and have that SOS function for the real SHTF moments when you're driving or hiking. I hate the idea of things going bad and my wife or I needing to remember how to actually use the radio for anything more than conversation.
My fear is this turns into something that gets in the way of people participating in the hobby. I am am member of a hiking group that has a small group of folks who can post activities. When they started the leader was a novice hiker and there were a lot of low level hikes. 10 years on and there are very few easy walks to bring people into the group. All the hikes are 6 mile round trips with 3K elevation changes. While most folks can do them, they can't maintain the club pace and they get dispirited and left behind.
I'm hoping that whatever system is decided as a core system is easy to use, learn and obtain. I'm a novice who doesn't even know what pressure I should have in my tires. I'd like to spend time fitting myself out rather than fretting over radio licenses.
