Overlanding with "stock" 4X4
Lanlubber In Remembrance
Mimbres, NM, USA
covey sr
stock?
doubt it. i see shackle reversals on some rigs, aftermarket tires on others, doubt that clutch is a repo 70 yr old design, or the brakes....or the winches........
every time these threads come up, i hear nothing but "ego" about modified trucks....
well if you think modding your tuck is for "ego" you can keep your humility....
....and your "stockness"
View attachment 151348View attachment 151349
just because YOU CAN...
I finally see why some folks need a jacked up truck, for TP delivery service !
  • Haha
Reactions: grubworm
ThundahBeagle
Massachusetts
Andrew
Beagle
":heavy mods are a handicap for poor driving."
silliest thing i've heard. seen bad and good drivers in both, stock and modified.
might as well throw this away...it doesn't matter what you drive...(long as it's stock)...
i can't imagine a situation where being at stock height is an advantage on mountain roads, rock crawling, trails, mud, snow, water, other than driving down paved roads.
modifications allow you to traverse the bush way more smoothly. don't need excessive wheel spin in mud, a buttload of throttle to get over a log, drown your truck in a creek, or drag the entire underside of your trucks over rocks. mods make it easier on your truck, instead of having to tear it up to get over that last hill, your driving out of the bush-the last place you need a breakdown....but feel free to tear up your stock truck...just make sure to post pics...:grinning:
stock is fine if that's what you like, but easier to maintain?? nahhhh, just another wives tale
to do an oil change on wifes '04 gmc requires car ramps or jacking it so i can shinny under it on my back inches from greasy cruddy parts, snaking my way around 800lbs of unneccasary crap, just to have hot oil run down my arm.
now take a look at this, changed the oil in my crew yesterday, no climbing underneath on my back, no ramps, no smashing my head or knuckles on everything, no oil running all over me. try to sit up normal under your stock truck and try this. waaaay easier, not even in the same league
hello ease of maintenance!
no head smashing needed, no lifts needed, no sore back
Just casual interest, but dont you STILL have to put that on ramps or jack up the front if you want the oil to drain out properly?
Having said that, starter replacement will be a breeze. Without any mods at all I shimmied under my '93 K1500 Blazer and reached up in order to get my started out an replaced. It was a breeze, so I can imagine how easy it would've been if I had even a mild lift. Can't say I disagree with you on ease of access.
However, the Mod cascade, as someone just termed it, can get out of control for some people's tastes.
I prefer a moderate set of mods. Shocks, springs, just to the point where I dont need to lengthen the drive shaft or drop the pitman arm or whatever.
Couple extra inches makes a big difference for must of us. Then again, I'm not rock crawling
Reactions: DaleRF
Atlost67
Bakersfield, CA, USA
Adolph
Lostaunau
Anymore I prefer a stock vehicle. Modifying as little as possible, keeping it reliable and easier to maintain. After decades of making modifications, only to have to modify something else to accommodate the previous mod. Sinking a ton of money into vehicles when I could have spent that money traveling and using the vehicle. Instead, I modify where I go. I had fun doing it, but I'm having fun now too.
edit: I should clarify what I mean by "I modify where I go." What I'm saying is that I don't take my Rebel the same places I would have taken my old built JK. Not that I modify the trails to suit my needs.
One of the best answers I've heard regarding vehicle modifications
@just_rich_young
Lawrence KS
Rich
Young
There's no right or wrong answer here. It's not about should you modify or not. The OP asked about the realities of overlanding in a stock vehicle. Everyone knows you can go more places in a heavily modified vehicle. I don't think anyone is arguing that. As far as maintenance, I'm speaking from my personal experience. Your personal experience is different than mine. Ever tried to replace a 37" tire in Central America? I've done the modified thing, but it's not my choice for overlanding. I've got a modified TJ in my garage, I'll choose my Ram over the TJ every time when it comes to overlanding. I'll choose the TJ if I'm going crawling.
LostWoods
Phoenix, AZ, USA
Andrew
lastname
i'm not into rockcrawling either unless there's rocks in my way. but a modded truck can go threw the bush more elegantly wit less drama. sure, makes for boring vids just driving over obstacles, but it saves on the equipment. never had a prob wit gravity either, unless i'm 10 bottles in....
yup, your fuel mileage will suck, but well worth the trade-off far as i'm concerned.
if you want bigger tires, and at a reasonable cost, can't stress enough, pick the right truck for what you want. most 1/2 tons will take up to a 35'er with no prob, bigger than that, you will want 1 ton gear. a Rubi is not the best candidate for 37's unless you want lots of mods and money.
i knew what i wanted, planned it out, bought good reliable gear and never had "cascade" probs. after more than 20 yrs wit the crew, i could have had 2 of them for what we paid for wifes '04 (new) in fact my crewy has had practically zero probs over the yrs, much less problems than wifey's stock gmc.
reg maintenance also goes a long way to trouble free travels....get intimate with your rig..
A JL(U)R or JTR will handle 37's just fine a long as you aren't the type to go full send on every obstacle... these axle housings are beefy and they're all 32 spline shafts. Trying to do the same on the TJ/JK D44's is just playing with fire.
IMO as far as new vehicles go (and totally not biased here), the JL and JT platforms are the ideal overlander for people who want to remain close to stock. You can go buy a Rubicon off the lot, slap some 35's on it, and go places many heavily modified rigs wouldn't dream of.
Dru13
Ft. lauderdale
Drew
W
Ive done the high lifted rig on mud terrains before. I also had the strait flowmaster 40 series exhaust. Although its plenty fun in the mud, it can get pretty bad on the highway.
If you ever had to drive for 10 hours straight you will go mad by the end of the trip lol. Also your MPG will be dreadful so be prepared to stop often, the constant droning from the tires and exhaust makes it unbearable. Also, you cant really go too fast so it takes way longer to get places. And trying to roll in stealth is out of the question.
Anyhow, it has its place. Most rock crawler guys have their vehicles towed in. I guess it depends on the person in the end though. I personally couldn't do it for overlanding. But to each his own.
Mimbres, NM, USA
covey sr
Nice being able to laugh at ourselves. I love the one about the covered wagon comparison, I've said the same thing about what I have witnessed with some OB'ers LOL
Kilo_17
Sedro-Woolley, WA, USA
Miles
Bergevin
I always get a kick outta the trick rigs in town with all the beef, but clean as a whistle day in day out, over the weekend etc. Never seen em out on trails or if I get to yak at some of em, I ask where do the go or have gone..... nowhere but the blacktop.
Not saying you HAVE TO hit the dirt to overland but damn, I've spent more time in gravel, dirt and mud exploring in my stock X on HT tires and love every minute of it. 20200505_033200.jpg
Kilo Sierra
Warren, New Hampshire, United States
Kyle
Seaverson
Not saying you HAVE TO hit the dirt to overland but damn, I've spent more time in gravel, dirt and mud exploring in my stock X on HT tires and love every minute of it. View attachment 153956
Nice X. It's kind of like my neighbor. I hear his mud terrains humming down my street but have never seen a spec of mud on it. To each his own I guess. I know he's seen my rig all dirtied up, but I usually rinse it down after I get back from a run.
Kilo_17
Miles
Bergevin
Oh my that pic looks like it ending fun!
Thanks, she is our second X now but this one is mine, standard trans an all ; ). I've got 2 more wildpeaks on order an the last 2 rims to paint up and they'll be going on shortly. Couple other odds and ends going into it but mostly maintenance to plus her up. I'm only upgrading as needed for now to take advantage of the capabilities she already offers in near stock form.
I try to keep it clean but never ends up that way haha
Kilo_17
Miles
Bergevin
Looked over your build thread and diggin it. I like the low profile of the bull bar on the F bumper too.
Is yours the OR model?
Kilo_17
Miles
Bergevin
and there's a flip side to that too. i reg wash my truck at least 4-5 times a month. i've seen what can happen when you leave mud and crap jammed in your rockers, or bearings getting eaten up with water and mud in your hubs.
some of us actually take pride in our ride and like keeping our trucks clean, and when wheeling an older rig (35 yrs old) there's nothing wrong wit extending it's life with reg maintenance.
only reason i'm posting this is cause i was filling up the other day and some guy in a stock nissan covered in about 50lbs of mud walks over to me and says, clean truck- ever take it off road?
i just told him "hey man, i don't need to leave 50 lbs of mud on my truck to make it look like a 4by"
I hear you 100% on vehicle maintenance and the like. Rotten rocker panels and wheel wells are not fun to deal with or accelerated wear to vital components. I was referring to the pavement queen/ mall crawlers where I live. A lot of them drive with an attitude like there shit don't stink or their rigs are superior because of the extensive mods done.
