![](https://www.overlandbound.com/forums/styles/OB/MasterBadge/trophies/nenthusiast3.png)
Anyone here running older Chevy’s, I have a 1979 K20 suburban 4x4 and looking for some ideas on where to start setting up
I’m looking at going for and everyday driver, that can handle most moderate trails, and capable of a week at least of campingWhat are ya gonna do with it ?
Influencer III
19540
Thank you for the advice, it’s already got a small lift and 31” AT’s on it, how long can you last with your 37 qt if just you by yourselfPut some AT tires on it and get a few totes for the gear. I would get a CO2 air tank or a good air compressor so you can air down and back up. For Moderate trails a stock 4x4 suburban will get you into most places just fine.
Then figure out just how much stuff you want or do not want to take. I would pick up a 12 volt fridge I have an inexpensive 37 qt but if you want to go a week I would pick up a 64 qt or something around that size.
To start with just take what you have a go camping and by all means look around at some of the build threads on this site to see what you like... Just getting out camping with what you have will help you figure out what you want to add to your set up. There are a lot of Tahoes and Suburbans that have some pretty cool stuff on them. Check out my build thread in my signature below and if you have any questions feel free to ask. I look forward to see what you do.
I actually work closer to Sulphur springs that I live, I’m in San Saba most the timeNice rig. Mine’s not quite that old.
Btw, we’ve had a couple of weekend trips up your way recently. Camping at both Oxford ranch and sulphur springs. Lots of dirt roads out there. @Mrprotaganist @Roots66
It really depends on what you are eating I have done 4 days with no problem. One thing I do is I carry a smaller ice chest with all my drinks in it, this will last about 4 days. After that I will have more room in the fridge if I want to cool any more drinks down.Thank you for the advice, it’s already got a small lift and 31” AT’s on it, how long can you last with your 37 qt if just you by yourself
I know it is a 400 ci sbc, it has the th400 transmission, but I’m not sure about transfer case and axles as of yetSquare body Chevs are a favorite of mine, there's so much you can do with them, I've been involved in a few builds. That guy being an old school 3/4 ton you won't have much to worry about drive train wise. You should be running a Dana 44 front axle and the full floating 10.5" rear diff. If it's an auto trans you should have a TH400 and a 205 transfer case. You basically have what I want to have for the basis of my dream build.
I'm going to bring in the 2 old school Chevy guys I know on here @AmericaMike @Rusty burbin
The late 70s 3/4 tons run the 44 front and 10.5 rear. Being a small block it will probably be running 4.10 gears. For the transfer case it will be a 205 unless it's full time 4x4 but I don't think a rig that old will be running the 203 case. Anyway, you have a great foundation. Just be sure to keep that 400 cool. Those engines don't have water jackets between every other cylinder ( called Siamese cylinders) so they are prone to over heating and cracking heads. But so long as you keep them cool they are a great engine.I know it is a 400 ci sbc, it has the th400 transmission, but I’m not sure about transfer case and axles as of yet
I do believe it would be the 203, the transfer case only has high/high lock, neutral, low/low lock, as for keeping cool, I’m going to pull heads and look to see if Previous owners installed correct parts, person I’ve bought it from told me it was a 350, casting numbers on driver rear of block indicate 400 so I have some investigating to doThe late 70s 3/4 tons run the 44 front and 10.5 rear. Being a small block it will probably be running 4.10 gears. For the transfer case it will be a 205 unless it's full time 4x4 but I don't think a rig that old will be running the 203 case. Anyway, you have a great foundation. Just be sure to keep that 400 cool. Those engines don't have water jackets between every other cylinder ( called Siamese cylinders) so they are prone to over heating and cracking heads. But so long as you keep them cool they are a great engine.I know it is a 400 ci sbc, it has the th400 transmission, but I’m not sure about transfer case and axles as of yet
Yeah, the funny thing about old school Chevys, you dont always know what you have. One of the biggest reasons they are such great rigs is the interchangeability. Unfortunately with that comes a necessity of knowledge so you can identify the major components like axles, transmission, transfer case, and engine so you know youre getting the right parts.I'm not sure either, but the visor still shows the factory 4x4 instructions, little hard to read these days, but still cool to have, I'll have to find out if the axles have been modified any when I get the chance
