![](https://www.overlandbound.com/forums/styles/OB/MasterBadge/trophies/nadvocate1.png)
We have a late 2021 Expedition 2.0 and I can’t help with the differences between the 2018 and 2021 versions and the specific updates. We selected the Expo over the Pando as neither of us are anything resembling a chef, towing with a Jeep so the 500 lb lighter weight was an important consideration and the departure angle being 50° was also important.Hi, I'm looking at possibly buying a 2018 Expedition 2.0. I'm wondering what, if any, the differences are between that and a new one?
Also, other than the departure angle and kitchen setup, are there any significant difference between the Pando and Expedition?
thanks for any help!
Doors are different. Older models have standard RV doors, heater will be on the roof vs side if it has that option, one less door inside of the trailer, probably minor electrical differences. That’s about it. The differences are fairly minor.Hi, I'm looking at possibly buying a 2018 Expedition 2.0. I'm wondering what, if any, the differences are between that and a new one?
Appreciate it!Doors are different. Older models have standard RV doors, heater will be on the roof vs side if it has that option, one less door inside of the trailer, probably minor electrical differences. That’s about it. The differences are fairly minor.
Thanks. I'll be towing with a jku rubicon, the weight difference is something im thinking about between the expedition and the pando, as well as the departure anglesWe have a late 2021 Expedition 2.0 and I can’t help with the differences between the 2018 and 2021 versions and the specific updates. We selected the Expo over the Pando as neither of us are anything resembling a chef, towing with a Jeep so the 500 lb lighter weight was an important consideration and the departure angle being 50° was also important.
Many differences between the 2018 Expedition and the 2022 model. Some have been already noted, but here's what I can recall: Larger doors, lighting package, provision for A/C, inside cabin bin doors that open down (not up) and can be used as shelves, furnace on the side box with the water heater, water tank level view port, optional heavy jack, pure sine wave inverter option, different fridge options, independent trailing arm suspension option, optional heavier leveling jacks that can (I think) lift the trailer to change a tire, and interior shelf option. There's probably more.Hi, I'm looking at possibly buying a 2018 Expedition 2.0. I'm wondering what, if any, the differences are between that and a new one?
There is no upgrade path to it, if you don't get it from the factory then you can't get it at all. Requires frame modifications and such.Anyone have any real world experience with the upgraded "evolution series" suspension? I'm feeling underwhelmed by the Timbren suspension and looking to upgrade. Wondering if its acutally worth it or just a cash grab?
In the Feb 2022 Video Off Grid Trailers Presents the OGT Evolution Series By Fabtech Motorsports, OGT says in the comments "We are currently working on a retrofittable options. We will release details on that soon." I haven't seen anything further on that topic. Did OGT decide against it?There is no upgrade path to it, if you don't get it from the factory then you can't get it at all. Requires frame modifications and such.
I spoke with Duane (President of OGT) while at Overland Expo West about this some more (I had a couple of comments on the retrofitting comment on their video), they have no plans to make a retrofit kit because of the modifications required to the frame as it wouldn't be just a bolt on change and as a result it would void their frame warranty. The only way to get the new suspension is on a new trailer.In the Feb 2022 Video Off Grid Trailers Presents the OGT Evolution Series By Fabtech Motorsports, OGT says in the comments "We are currently working on a retrofittable options. We will release details on that soon." I haven't seen anything further on that topic. Did OGT decide against it?There is no upgrade path to it, if you don't get it from the factory then you can't get it at all. Requires frame modifications and such.
You say you're feeling underwhelmed by the Timbren, can you be more specific? Also, what PSI are you running in the trailer tires? I ran 35PSI initially but was told 26PSI worked well all-around. My initial complaint was feeling the trailer being a bit bouncy and tuggy on rough pavement, this was before we had actually taken it off pavement. Lowering the PSI to 26 made a world of difference.I can’t say that I’m surprised. Thanks for the info - appreciate it.
I think this was directed towards me.You say you're feeling underwhelmed by the Timbren, can you be more specific? Also, what PSI are you running in the trailer tires? I ran 35PSI initially but was told 26PSI worked well all-around. My initial complaint was feeling the trailer being a bit bouncy and tuggy on rough pavement, this was before we had actually taken it off pavement. Lowering the PSI to 26 made a world of difference.
Earlier this month we got back from 1.5 weeks in Colorado with quite a bit of off-road towing and while I'm sure the new suspension would make a noticeable difference over the Timbren, I was satisfied with how the Timbren worked. It was never super bouncy or jarring, at most there would be a large rock/root/log that would cause the trailer to gently rock while going over them. We had various things loose on the mattress plus we had stuff in the Pando sink and all of the storage cabinets as well as sitting on the full-width front shelf and at no point did anything get chucked, knocked over, or fall. I didn't air down the trailer tires at all, still ran 26PSI.
What pressure are you running in the trailer's tires? I had mentioned what I'm running but I don't see you mentioning what you're running (or if you changed it from when the trailer was delivered). I also don't know how loaded down you are, but we had both water tanks full, both fridges full, quite a bit of food and clothing in the storage compartments. No RTT, though. 26PSI has worked well for me on pavement and off-road. If you're still running 35PSI or whatever came from the factory then that could be a lot of your problem, the tires are bouncing more than conforming. The Timbren suspension has been working well. Not as great as the upgraded suspension but I'm not feeling like I need or want to upgrade yet.I think this was directed towards me.
The trailer is a dream on the highway. It's so tiny I forget that I'm pulling anything in my Gladiator. I'm just finding that the trailer is flying all over the place when off road. I'm concerned about beating up the water/propane/electrical systems. I'm already having issues with the water system (I'll say that dealing with the warranty department has been painless though). I'm not bombing through the bush or abusing it or anything too wild, but occasionally there is the odd unexpected bump and the trailer is not reacting well to it. I could see a huge benefit in having a proper suspension setup.
That's a shame if its true that they won't be offering an upgrade path. I was told by Chris that they would be when I bought it.
I'll chime in with my experience. I run my 2019 Expo on the road with 30 psi in BFG KO2 tires. (Fully loaded, no RTT.) No issues with trailer bounce. Offroad, of course, the pressure depends on the trail condition, but around 18 psi is typical. The Timbren suspension is fine. The new suspension option looks great, but the trailer ride height is increased. I'm not sure I'd go for that if I was buying now because my tow vehicle is not lifted and I'm already running a rise in the hitch.What pressure are you running in the trailer's tires?
35 on pavement, 25 on gravel, 20 off-road.What pressure are you running in the trailer's tires? I had mentioned what I'm running but I don't see you mentioning what you're running (or if you changed it from when the trailer was delivered). I also don't know how loaded down you are, but we had both water tanks full, both fridges full, quite a bit of food and clothing in the storage compartments. No RTT, though. 26PSI has worked well for me on pavement and off-road. If you're still running 35PSI or whatever came from the factory then that could be a lot of your problem, the tires are bouncing more than conforming. The Timbren suspension has been working well. Not as great as the upgraded suspension but I'm not feeling like I need or want to upgrade yet.
