OB Members Map!
Status
Not open for further replies.
flash_gordon
Pueblo, CO, USA
Shawn
Davis
Just checking in, no member banner after following the link. Member #16502
Thank you!
EDIT- I followed the link a second time and pasted the code in once again, all is working now!
MtnBnd
Riverton, Utah, USA
Ray
Kirby
Hey Everyone that's having issues seeing the Map info. I sent Michael a message and this is what he responded with...
"Your account has not been activated! When you ordered, you should have received an activation email with your Member number and activation code"
I hope this helps.
Andrew Farnsworth
Lawrenceville, GA, USA
Andrew
Farnsworth
I was having issues with upgrading my account as many others are. Check your junk box for the second email with your member number and activation code. Only that email from OB was sent to my junk box.
Festus
Williamsburg, Iowa 52361
Good evening. I am currently stumbling my way around the website. I am not able to see any data on the map. Is there something that I need to be doing to activate the map? I also have this annoying message in the lower left portion of the browser window that I can't seem to get rid of. Is there something I need to do to rid myself of that? I will post a pic of what I see from my side if it would help.
gDanCO
Thornton, CO, USA
Ditto here. I retried the activation code. I'll sign out and sign back in to see if that works.
Did not work, need to go through the web sight to see if I can figure it out or ask for some help Monday...
Chuckem12
South Florida
Charlie
Has there been any update/correction to the map issues? I'm still trying to update my location but I'm not given the option.
gDanCO
Thornton, CO, USA
If the recent system updated did not correct the issue, email the office and ask for them to manually enable your account. That's what I did wwnenI could not access member on the site.
AZPAJERO
Scottsdale
Can someone from home office manually "enable" my account? I'm a member and don't have access to the map for some reason. Member #13719
Status
