Tahoeppv I’m retired usaf myself. Where is bud atc I’m in Alamogorodo no. I’m not quite setup yet. My major problem is sleeping quarters . Rooftop tents are out in top of the jl. I’d like a medium to large off-road trailer as I like my creature comforts. I’m disabled between my neck, back arm and legs.my neck suffers from spasms where scar tissue is pressing on the nerve ruse yhat run down my rt arm ans shoulder. My lower back prevents me from stand and walking if I stand I get pain running from one upper hip area to the other across the back intensifying as I stand. If I remove the pressure by sitting or laying down. My hand have neuropathy so they work but not very well I drop more stuff than I get right. Now both legs suffer from neuropathy which for me makes them numb from the knee down. Imagine walking on two wooden logs as legs you can’t feel your footing or much else. I also duffer from sleep apnea which I think I have under control using a goal zero. I’ve reached out to neurosurgeons in El Paso,and las cruces and both declined my case.
that’s what I’m up against. A ground tent might work on some trips as long as a cot can be used since it very hard for me to get off the ground. I have a bunch of trail equipment including a air bag. Several stapr, tree savers and both hard and cost shackles. Air compressor. I have the semi major parts for a camp kitchen for a couple of people. Small single burner camping stove, collasable bucket and basin plus a drain rack. Somewhere is a shower or kitchen water source.plus anotherwater source that you pump with your foot. My problem with the jl 2door is being able to transport everything.I have a dometic CFX3 3 fridge which I’m quite impressed with.
incase I never stated the ride it is a 2020 Jeep Rubicon Recon JL 2 foot in hellayella. It has a light bar above the windshield and Incase I need to back up one across the back the front has two little pod lights at the base of the windshield.. I carry my Hilo farm jack across the loop above the winch. The winch is a warn evo 8k synthetic with a factor 55 end. Inside the comm will run from cb to grams and eventually ham once I dettled down and stud at for and take the fcc test.kits inside include first aidkits, recovery kits, tool kits, diagnostic kit. Mods to add light strip over open tail gate, third brake light strip fot stop , turn and backup lights. Grams radio and antenna. I wish to organize everything better oncethey are in soft cases.then put the fridge in after the genegig dual battery kit is installed with the in cab monitor and rear mount 12 volt receptacle.
I would like to find and used frond sleeping trailer at a great price for over landing.
I have a superc Motorhome for use to get to locations but it’s not off road capable.
So I guess until the trailer is aquired I’ll need two things one some one to assist in setting up camp and the other is the sleep quarters with cot and pad ar a minimum for me I have a tent cot but I’m not sure how that will work for me and my dog.
Any ideas please chime in
any body that needs a ride ans can assist me we shelter and aide let me know preferably in the Alamogorodo area for startingout trailheads in ruidoso cloud Croft or surrounding areas at least in the beginning.
