![](https://www.overlandbound.com/forums/styles/OB/MasterBadge/trophies/nenthusiast2.png)
Nice! So, is that a permanent installation for your rig? Any suggestions for how to lift and attach the tire to the carrier - does it take two persons?
So the spare is on the roof, surely you have a plan to get it down when you have a flat on a trail ?How to lift and lower the tire without damaging the side of the Jeep? Thanks!
Well, as a matter of fact, if someone wants to organize an overland trip to Tierra del Fuego, I’m in!If the picture is of your vehicle then it looks as if the tyre on the ground is HT, so your first step is to change to ATs - which you have done.
The next question, as others have asked, is whether you need a second spare? After 3 "big trips" South America, Africa, Australia (139,000 Km in a total of 30 months) we have concluded (more details on request) that a second tyre is just not necessary. If you're planning a trans-Sahara trip away from all infrastructure for a month or two, maybe, but otherwise it's more weight and inconvenience.
Also as others have said - get a repair kit and a compressor (which can be small and light) and don;t take a second spare.
Ii tally, I did successfully mount the spare tire carrier on my own. But, I got hurt the last time I tried to mount it. Didn’t want a permanent installation. My wife hated having the hitch mounted tire, because it blocked the backup camera. Also, even though the Wilco has a receiver for a bike rack, mine didn’t fit. I have a special Thule bike carrier for our ebikes, which are heavy and so you need a specialized carrier for ebikes.I 100% empathize with your concerns about ruining trips from an early flat. I've mentioned before that I had an entire fun day with my son ruined once because of a flat.
However, I can't think of very many options that would be safe for you. Wrestling a tire on and off a rim to do an aggressive temporary repair--internal patch or even sewing a tear shut--is not easy work. Wrestling a tire on and off the roof is probably even more dangerous, even if theoretically simpler.
Question..... was it not possible to simply have somebody else mount the hitch carrier for you? Or, did your injury mounting the hitch carrier make you worry that you'd likely get just as injured messing with the spare itself?
Finally, what about a donut spare? A 35lb donut should be a lot easier for you to wrestle onto and off the roof (or be small enough to just toss in the back with the rest of your gear). At least this way you can carry 5x full-sized tires, and if you end up destroying two beyond repair (which is incredibly unlikely), at least you'll have a way to make it to a nearby town or something to get a more suitable tire for the return trip.
This is the key point. Destroying two tyres beyond repair is very, very, unlikely....and if you end up destroying two beyond repair (which is incredibly unlikely)....
I thought I'd add some more information and explain why we now don't now carry a second spare.
On this type of trip our experience is three "big trips" and lots of shorter trips .....
Thanks for the insight from your (extensive) personal experience. I am planning some ”longer” trips and have wondered about the wisdom of a second spare. My concern is the added weight and based on your comments I will stick with one good spare and a good tire repair kit. Any more expeditions planned?
Expedition Master III
---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Hi James, unfortunately the Jeep Grand Cherokee has a lift back so unlike a Wrangler there's no way to mount a tire on the back. Still hoping for a solution that doesn't involve trees! Ha!
