Wow, 14" of ground clearance? Are you measuring that from the lowest point on the underside of your car? If so, that's amazing.The new model Subaru’s have what they call X-Mode. It recalibrates the gearing & engine mapping. It softens the throttle response & by using lower gear ratios it generates extra power on the wheels that have grip. It deactivates the transmission’s lock-up clutch. It will apply braking only to the wheels that are slipping & it raises the front/rear coupling force. So... it kind of has its own brand of low range.
As far as the ground clearance - I have about 14”. The biggest downfall of the wagon is it’s poor approach & departure angle.
