Minimum clearance
genocache
Boulder Creek, CA, USA
gene
L
I was going to suggest a Sherp. The reality is as others have asked, what is your definition of anywhere? The Sherp comes the closest to fitting the bill.
An aluminum bodied 109" Land Rover with a LS engine and a autobox sitting on 8" -35's on Portal axles, fully locked, diesel if you want more range, dual tanks, dual batteries.....etc
That keeps it with low center of gravity(no RTT), great power, good lift, ability to put all you camping gear inside and sleep inside. That will give you a narrow, 60", body and the ability to go where most fear to tread.
Can't swim, through the swamp like the Sherp though........
Reactions: MazeVX
Billiebob
earth
Bill
Hey everyone,
So I want to build a rig with enough clearance to go anywhere in Canada but I also have concerns with my build being so top heavy that it rolls over if I take a turn on a windy day
Does any one have any advice as to ball park figure minimum clearance to shoot for?
Best regards,
Nick
Buy a Wrangler, any stock Wrangler and be happy.
Add selectable lockers front and rear or just buy a Rubicon.
Add a winch, carry tire chains, use season appropriate tires, tread lightly.
ps an '03 Rubicon is as capable as a '21 Rubicon.... maybe more so since the '03 is lighter..... and likely already pinstriped.
Dusther210
Pioneer II
6,020
Oakland, Bergen County, New Jersey, United States
Dustin
Helms
KD2UNH
USAF
I am currently helping a friend purchase an adventure rig and I am coming to the conclusion of what @Billiebob said. A well armored JK on 33s does so much. Add a little lift for good measure and with a winch and a lockers and it’ll go anywhere. Put 35s on it to go anywhere more comfortably and with less fuel economy
Montréal, Quebec, Canada
Nicholas
Monte
I have no I sea where I want to go as I've been over landing to only 1 location so far
MazeVX
Gießen Germany
Mathias
Kreicker
That's about what I have... Coarsely... Jku diesel on 285/70r17 with 2.5" lift, no locker no winch. Did all I asked, plowed through hundreds of meters of mud puddles and climbed sharp edged rocks on steep mountains.
Camps two people easily.
DevilDodge
Altoona, Pennsylvania, USA
David
Spencer
Your absolute best bet...go where your current setup allows you and spend more time going to those places.
Spend your money on fuel and food.
Most places...going anywhere is illegal. Find out the area you want to explore...and EXPLORE. Go to the same area twice...but find a different route.
Go hiking to a section you can not drive...that is how you go anywhere.
My opinion...i just go where I can with the vehicle and setup I have. The only places I can not go...are the ones you are not able to anyways.
DevilDodge
David
Spencer
Yes I agree but to high leaves you vulnerable to tipping over on turns on windy days. I'm thinking 10" clearance is ideal
The limiting factor for ground clearance on a truck will be the differentials...maybe shock mounts on the axle also.
The only way to change this is with larger diameter tires. My use case is to always get the largest tire to fit stock.
I do not even think of lifts or such...as I use my vehicles for a purpose and the bedsides are already too high and the tailgates at about the right height.
10 inches is not gonna get you anywhere...but it will get you most everywhere.
Most full size trucks are right around the 9 inch range factory. So seems like they thought about the same.
genocache
gene
L
Taller tyres are 1 way to raise the diff height, portal axles are another and not as cheap........ I'm just saying.
Alanymarce
Trail Mechanic III
1,392
Colombia
Only if it's a solid axle - IS will permit a lift which increases the clearance for the differential housings. Also by sticking to standard (or near standard) wheels/tyres the gearing will remain the same and the stresses on the drive train will not increase above the original design rating.
Arailt
Prosper, TX, USA
Brian
Arailt
It's a give and take either way you look at it. Lifting independent suspension to get substantial clearance increases changes the factory shaft angles and puts additional stress on the ball joints and boots. IS diffs are weaker than solid axles and they have far less articulation to begin with. Lifting IS makes that worse. Plus, even though you might gain clearance in the center by lifting IS, the low points on the control arms wouldn't change without increasing tire size.
Portal axles FTW :sunglasses:
MidOH
Mid Ohio
Clark
YourHighness
33" is fine, for up to half ton trucks in my AO. 35" for F250 or larger.
It depends on your definition of overlanding. The Mercedes motorhome guys would love to have larger tires and clearance. But seriously, where would they go anyways?
Some Jeeps or Taco's do fine with less.
Alanymarce
Trail Mechanic III
1,392
Colombia
Good points - perhaps the key is what we mean by "substantial clearance". If looking for what I think of as a reasonable lift for overland travel (landfaring) then the increase in stresses is not that much compared with the benefit of 50-75mm added clearance. The main benefit if this added clearance is to lift the differential housing to clear the hump left by the other vehicles on the tracks. The low points on the control arms will be in the ruts so less of a problem.
If one is looking for more than 75mm or so then the stress issue becomes more significant, I agree.
MidOH
Mid Ohio
Clark
YourHighness
True.
But when you arrive at your destination, and every darn time, there's a crew cab fullsize truck there, you'll be hating the jeep pretty quickly. If there's crazy Subaru women circling a Mercedes Sprinter thing.........arrgh, that's even worse.
That's what happened to me. Going from YJ to a Superduty, was like going from ultralightweight backpacking in a dust storm, to drinking fine wine on a cruise ship. Real AC, 90mph = no problem, two giant coolers, driving in a tornado, snow, etc. etc.
Doing wide open spaces, park roads, places Hmmwv's can go, in a small rig sucks. Taking a fullsize to tight trails sucks.
Reactions: Dusther210
Alanymarce
Trail Mechanic III
1,392
Colombia
...or, restated - Doing wide open spaces, park roads, places Hmmwv's can go, in a small rig is less comfortable. Taking a fullsize to tight trails can be impossible .
