Expedition Master III
It's not just if a bumper will accept them, but where on the bumper, the provision is made. By that, i mean, are the sensor provisions in the same location as the OEM ones? This is a very important consideration, as the sensor wire will not have very much slack to reach the new sensor position, if not mounted close to the OEM bumper provision. Imagine buying and installing a bumper, only to find out the added dollars you spent for a compatible upgrade was wasted, because they don't reach.They should be. Take a tape measure, measure distance to ground, add 6 inches. That's about how high a high lift will be to remove a tire. I have notches in my bumpers for a high lift to fit into. No way to slip off. I used them in the driveway to see how well they worked. My high lift was almost at the top. If my vehicle was a bit higher, I would have to get a taller high lift.
This is a problem with modern trucks and will most likely raise the price of the bumper. From what Ive seen, on most trucks the sensors look like they should be easy to swap over provided the bumper accepts them.
I went to look at a dodge truck last year. A friend replaced the bed with a flat bed. The sensors on that truck were in the tail light housings. They wanted me to make them work in the aftermarket rear lights on the new bed. It wasn't possible and no one made a "universal" sensor I could use. As far as I could see, all it did was disable the vehicle lane change detection and turn on a light.
Gear threads are always attracting my attention, especially when they are vehicle related. It doesn't matter what brand, it's the gear to make them better that fascinates me . The input from 'many' is more informative than any manufacturers slick advertisement. Real world reviews, and input, are where you get honest answers.
