Heads up if you go larger tires
9Mike2
Garden Grove, California
You are probably not going to find it in an overlanding rig, but I recently read that there are some vehicles, BMW(?), that have lasers in the wheel wells that track tire size and automatically adjust the speedometer.
Light sensors ? in the dirt and mud be aware.. I went with the AEV Programmer..
Reactions: Ubiety
peeeeetey
Harrisburg, NC, USA
Pete
Meuser
GMRS WREL270
I don't know who owned it or what that person did before I bought my vehicle but my speedo runs 5 mph slow since I bought it, I run standard size tires. I just drive 5 mph over the marked speed limit. Never had a problem with the law.
Reactions: 9Mike2
MOAK
Donald
Diehl
WRPN 506
Cool but sounds expensive if it breaks.
More than likely a device that measures ground speed like the ones used in agricultural equipment. Spray rigs in particular.. for my vehicle I know that if a tire is 1” larger then stock, add 3%. mine are 2” larger than stock so add 6%. If my cruise is set at 62 I know I’m actually doing 66 mph. Same with mileage, if the odo says I’ve traveled 100 miles, I know I’ve traveled 106 miles.. knowing this is a lot cheaper than worrying about recalibrating my Speedo.
Reactions: 9Mike2
9Mike2
This works in most cases, but if the area you are driving through are having a "Max Enforcement" ie. speed, DUI ,
excessive lane changes and such, they will cite for three MPH over...
