Traveler II
21876
I did the same thing for my TS-480. It works ok, I do like the easy of removing it, but the control head does rotate a little bit over rough roads.
Do you have a link to the ram mount you mention?
Traveler II
21876
yup that's what I did. So far so good, but I didn't like how it still swiveled slightly.
The bend helps the signal get around obstructions.Brand NEW Antenna just dropped off by amazon...is this supposed to be bent? It is a NR770HBNMO Mobile antenna 2m/70cm, NMO, 40in
The bend was so perfect I just didn't know. New one (replacement) will be here Monday... Amazon has its good and bad sides....The bend helps the signal get around obstructions.
Just kidding, nope, supposed to be straight.
If they let you keep the bent one, just run it and stash the second one for a spare. The bent won't hurt. My dual band has a lot of interesting kinks in it from its time in the woods.The bend was so perfect I just didn't know. New one (replacement) will be here Monday... Amazon has its good and bad sides....
Send it back, it should be straight. Try the Larsen 2/70B antenna.Brand NEW Antenna just dropped off by amazon...is this supposed to be bent? It is a NR770HBNMO Mobile antenna 2m/70cm, NMO, 40in
Yaesu is having a sale that ends tonight... The FTM-400xdr is 100 off right now, not sure what they are marking down the FTM-100DR to.I run a Yaesu FTM-100DR, it is a great radio. I have been running it for 2 years now and if I had to redo it I would buy it again. $254.00. Here is a link for it.
