I don't plan on staying in the desert long. I'm from then evergreen state. It sounds that Jet hot or another ceramic coating is the best.I was going to bring that up, but then I re-read the first post. Based on his listed location, I don't believe he will have any issues with that. Note the absence of green and blue in this region.
I understand they made theses engines to run at certain temps. Engine temps I think are fine if I maintain coolant levels. Long-life and how well everything is running is what I am looking for. I just want to make my truck last. And that is if I am crawling up a dirt road, flying through mud or rolling down the interstate.Do you want to lower engine bay temps or the engine’s internal temp?
Wrap will significantly lower the life of the exhaust, jet hot can’t be added yourself. You buy jet hot coated headers. I’ve had really good luck with Eastwood ceramic exhaust coating. The key is the you have to coat the INSIDE of the exhaust to minimalize heat retention in the exhaust components. If you don’t have an overheat problem lowering the temps Underwood won’t really net any longer component life. Lowering the operation temps can hurt as much as help if it’s in spec. The engineers designed it to run a certain way.
Auto meter makes some awesome gauges that have a fairly stock look and they are good quality.
Thanks for all the input guys.
