Boostpowered
If your replacing a thermostat you might as well get a new water pump and hoses too, see how things snowball out of control on used vehicles.Thank you, I will do that
Since you change that often i have a question. How often do you actually find water in the diff pumpkin? If that often you might want to invest in new axle shaft seals. A tip to anyone doing water crossings if youve been driving for a while especially in 4wd and you come to a watercrossing, do not just drive across if the diff is hot and you submerge it the rapid cooling is what suck the water through seals, stop before you cross get out and enjoy the scenery for 15 to 20 minutes let the diff cool off then you can cross without water being sucked in. If you just cant wait to cross and you go in water often think about pressurizing the diffs with a onboard air tank. Ive always used the stop and cool method and have never had a problem with water infiltrating my diffs and im in water quite a bit. I generally only change diff oil 1 to 2 times a year depending on how much hauling i doIf you aren’t running anything needy fluidwise(Like fluid particular lockers or such) I typically run cheap fluid of the proper spec and change more often. It’s VERY rare I get 30k out of diff fluid in a 4x4 before I’ve had some water crossing or boat ramp possibly contaminate it. I’ve found that it’s much more cost effective.
2 GALLONS of 85w-140 AND a garden sprayer I converted to a fluid pump cost less at the local tractor supply than 2 Quarts of the expensive synthetic I run in my fancy locking rear diff on my BMW.
Things can definitely snowball on older vehicles.If your replacing a thermostat you might as well get a new water pump and hoses too, see how things snowball out of control on used vehicles.
Unless the seals are leaking theres no reason to replace the water pump, if hoses are still soft, they are good to go too. T stats are a good idea as they are the most susceptible to failure due to lack of cooling system maintenance, and they are cheap. A water pump will "fail" long before it stops actually working, T stats not so much.If your replacing a thermostat you might as well get a new water pump and hoses too, see how things snowball out of control on used vehicles.
Might as well put in a new radiator cap to go along with the new thermostat.When you have the coolant out, you should replace the thermostat too.
