![](https://www.overlandbound.com/forums/styles/OB/MasterBadge/trophies/nmember2.png)
So, I had the opportunity to run Moss Wash in Kingman with a good friend on Monday 10/1, and boy oh boy, were the discoveries we made on the interesting side. I used the trip as an excuse to shake the dust off of my tablet and use it to navigate, and pull data off of the OBDII port. The overall results of the trip we're nothing short of excellent. This was the first moderate, non-exploratory trail she's been on in about two years. So, two years of mostly untested, fresh refits put to the test. The suspension cycled great, but will be phenomenal once I get extended brake lines and coil retainers bolted up. The new transfer case took the abuse no-sweat.
And the one that made me nervous of course, engine performance. The 4.7 surged forward with very little issue, finally! Engine temps remained under control, and oil pressure remained higher than previous. The re-worked cooling system kept the Jeep between 190-208 degrees, which is pretty spectacular for crawling up the side of a mountain. On flat and downhill crawling, it would at times dip as low as 180, which is as (absolute) low as you want it to potentially go. I haven't really had a chance to look at other factors until now, either. The reworked intake & snorkel means that air at the manifold is anywhere from 10-20 degrees cooler than stock! Once I insulate the plumbing for the intake, it may drop further, too. I'm very pleased with the performance overall. It's very gratifying to have all that hard work come together like it has.
And some questions were further dug into....
One thing we noticed is that my 1st gear crawl ratio seems steeper than the later model WJs. We were wondering if maybe this ties into the previous "Factory WJ/WG Hybrid" idea. In 1st, 4-lo, Pegasus will pretty much just crawl over just about anything on it's own. Curiosity continues to grow on this topic.
First time leading a trail run of any sort, too. Exciting!
![20181001_124326.jpg](/forums/data/attachments/72/72193-332b3196b495d4f5baf60124b6485443.jpg)
![20181001_133535.jpg](/forums/data/attachments/72/72194-34ece2547799366584b5c4db94b063c1.jpg)
![20181001_121929.jpg](/forums/data/attachments/72/72195-d110a5c1c9ff0048332abbae68c6ebca.jpg)
