You're going to want to get the deflector as close as possible to the front of the vehicle, touching the roof if possible, and then angled back to block the front of your rack. http://www.frednelsonfabrication.com/P38RoofRack/P38 installed roof rack (4).JPGWell. It works. but the drumming noise @ 50--70 MPH is terrible. Now I have to figure out how to fabricate a wind deflector. Not sure whether it needs to between the rack and roof, or on top of the rack.
So much for making one that was low enough not to make noise.
Yeah I know that's the usual set up. To do that on my 4runner, it'd be stretched from the windshield all the way back to the rear of the front door. That nearly the length of the rack itself. I'll keep dicking around with it and get it to quiet down.You're going to want to get the deflector as close as possible to the front of the vehicle, touching the roof if possible, and then angled back to block the front of your rack. But I don't think it will help the droning as much, you may have to get used to it, mine does it and I don't even notice anymore unless I listen for it.
My fault, I meant "front of the rack", not the vehicle, and touching the vehicle if possible, you can keep your rack where it is at but still put a deflector on it, doesn't need to be near the windshield to at least help a little.Yeah I know that's the usual set up. To do that on my 4runner, it'd be stretched from the windshield all the way back to the rear of the front door. That nearly the length of the rack itself. I'll keep dicking around with it and get it to quiet down.
Not sure if the cost question was posted in reference to my post about the Sorbothane Vibration Isolation Bushings or the original rack post. I don't know how much they cost I work around large highspeed presses and we use them to isolate vibration between components and pre/post equipment. (I've salvaged a few over the years and used them under my home built CNC Router and on my simple 3d printer.)Cool. How much did they run you?
Paint is flaking in a couple places. I expected as much. Sanding all of it would have been very tedious so I wiped it down with aceton and sprayed it. I did take the hinges off and shortened it by one section. I secured the three separate pieces to the cross bars from underneath using riv nuts and stainless bolts.Hi- any particular painting method? I hear paint doesn't adhere to aluminum that well, how is yours holding up?
Looks like you cut off the hinges? Did you do anything to get the 3 pieces to seam together so nicely?
Looks great!
