I see zero evidence of any leaking on the t-cover, so I wasn't going to mess with it as this snowball is already growing. That said, I sort of just decided I'm going to do the front crank seal, so the balancer will be one more thing that will be already out of the way. To do the passenger-side valve cover I'll need the AC compressor out of the way... so that will pretty much leave just the alternator to just go ahead and do the front timing cover reseal. Hmmmm...Since you are already so close why don't you reseal the timing cover? The upper o-ring is the one that likes to leak and cause these things to overheat.
Looking up parts on my 4.7 they list 2 versions, a "1st design" with the gasket and a "2nd design" that comes with RVT, no gasket (both have the O-rings, just a question of whether they're separate with RTV or if they're part of the overall gasket). I guess I won't know which mine has until I take it off... darn it I'm starting to think I better just do it.I just resealed my wife's 2006 WK 4.7. It wasn't to bad. I'm not sure when they changed over, but her timing cover was all RTV (no rubber seals).
Thanks! It has a long way to go, but it's a lot of fun.This thing is looking pretty awesome. I'm going to have to keep a eye on this!
My wife's listed it for o-rings and RTV. The kit came with RTV along with the o-rings. I picked up some extra, but the stuff that came with the kit was good and there was plenty. The kit For hers was FEL-PRO TCS46022 from Rock Auto.Looking up parts on my 4.7 they list 2 versions, a "1st design" with the gasket and a "2nd design" that comes with RVT, no gasket (both have the O-rings, just a question of whether they're separate with RTV or if they're part of the overall gasket). I guess I won't know which mine has until I take it off... darn it I'm starting to think I better just do it.
-TJ
Thanks, I ordered both options from Rock Auto, also went with FEL-PRO. Now, do I go ahead and do a timing set if I'm going to have the valve covers and front cover off...My wife's listed it for o-rings and RTV. The kit came with RTV along with the o-rings. I picked up some extra, but the stuff that came with the kit was good and there was plenty. The kit For hers was FEL-PRO TCS46022 from Rock Auto.
TJ,I see zero evidence of any leaking on the t-cover, so I wasn't going to mess with it as this snowball is already growing. That said, I sort of just decided I'm going to do the front crank seal, so the balancer will be one more thing that will be already out of the way. To do the passenger-side valve cover I'll need the AC compressor out of the way... so that will pretty much leave just the alternator to just go ahead and do the front timing cover reseal. Hmmmm...
-TJ
Thanks, that's a great tip. One of the FEL-PRO kits comes with RTV, but I'll run the Mopar stuff.Go to your closest Mopar shop and get a tube of 3-bond. It is by far the best engine sealant i have ever used. Hondabond a close second.
Yeah, I hadn't planned to get into the front cover, but now that y'all mention it and I look at how little extra work it is I guess I'd be crazy not to. The timing set is another thing though. I think if there's no signs of wear, all the guides look okay and no obvious excess slop I'll leave it alone... but perhaps that's crazy too?TJ,
I know how you feel and I am only towards the end of the parts buying stage for my cooling mod.... the stack of parts is growing exponentially.
I figure with over 135k on the 4.7s clock, I'll likely be replacing the engine within 5-7 years anyway (if lucky!!) so I am only going so far.
Other than motor mounts, my other extra is to replace the oil pan gasket since it leaks pretty bad when going up hill.
JImbill
To my surprise, it fit perfectly. I had concerns but it worked great. The pics don't do a great job of showing it but everything is going to lay-out perfectly to go back to the stock, giant PS cooler too. Also, I forgot to mention I hit the areas where a previous battery had leaked with battery terminal cleaner a few times. They're 98% clean now, but I'm going to go back with some denatured alcohol and scotch-brite, then hit them with a rust-prohibitive paint.Looks good. Did the '99 high pressure line standard threads match the steering box?
At this point you are not far from a long block, especially if you factor in your labor and vehicle downtime.Well, I couldn't stand the idea of not doing it right... so I ordered a timing set (Cloyes), hydraulic lash adjusters (most ppl call them "lifters" but they're not of course on these SOHC motors), spark plugs and a few other misc odds 'n ends...
...maybe I should just pull it and rebuild it? :p ;)
-TJ
Yeah, I was just kidding about that. But like I said I'm doing the timing set and the lash adjusters. I just could not justify having the front cover and valve covers off and NOT doing them. This whole Jeep has been meticulously maintained, so I hope the rest of the longblock has another 100k in it...At this point you are not far from a long block, especially if you factor in your labor and vehicle downtime.
I bought the complete tool kit, including that tool. Luckily no, it didn't ever overheat (I did do a combustion gas test on the cooling system before I began any of this to check for head gasket issues and it came back clean).There is a special tool to hold the chain in place while you line everything up and also one for taking the lash adjusters out without taking out the cam shafts. Did you ever overheat at all when it started leaking coolant?
The biggest problem is that the valve seats will come out and destroy the engine within a year of it is ever overheated. You can buy reman heads that have revised valve seats.I bought the complete tool kit, including that tool. Luckily no, it didn't ever overheat (I did do a combustion gas test on the cooling system before I began any of this to check for head gasket issues and it came back clean).
-TJ
