I have trust issues. I want things done right and that is hard to find these days. I have a local indy euro shop that I hope that if I ever have a major issue that they could help. I can't really tell how good our dealer is. The techs could be awesome, but usually get hidden behind the service managers. Plus it's pretty pricey. Sometimes my time is worth more to me than the cost, so I will have it done, but I am being pretty careful with the LR4.
So far all my modifications have been done in my garage by myself and my father. The ARB bumper was quite a bit of work, and involved cutting fenders, but I know for sure it was done correctly. I've only had to replace an alternator on it so far with no other faults.
Modern rovers really are very reliable, despite the continued relentless and frankly mindless talking points that certain brands are infallible and perfectly reliable. With most things its about maintenance. I especially see these talking points a lot from owners, of various brands, who do NOT wrench on their own vehicles. That being said, some (specific models of) vehicles just require more care, that is true, and that *is* due to design choices. LR4 for example needs occasional love primarily due to 1. they chose to make it super comfy 2. they chose to make it weigh between 6k and 7k pounds. Comfy squishy bits and other things wear out.. e.g. suspension hydro bushes, wheel bearings etc. But with proper maintenance, you wont get stranded. You can't say a rover isn't made for harsh off road travel, even the soft looking new ones. They have diff breathers from the factory and engines with oil sump pickups meant to work at 45 degree angles, and sump plates, and actual rated recovery points front and rear.... You can't say that about most off road makes.
I think it is a good idea to be confident you can wrench on your vehicle if you want to do remote travel. You at least have to understand what is wrong when something happens. Know how your suspension, brakes, starter, alternator, battery system, etc work. Know how to change a wheel bearing, plug a tire, fix a tire that is off a rim. Know how to change out a tie rod on IFS vehicles.
Also good to have a code scanner with you, and even better a specialized tool (like an GAP diagnostics IID tool if you have a modern land rover). It can put the computers in various modes, manually pump up air suspension if you loose a sensor, and disable parts of the system to get you going again.
Takes time to get to know a modern vehicle though. I found this diagram recently, a "quick" reference for connectors on my LR4...
