In fact, You can get 5100s for a stock hight Tacoma for 339$. THAT is an incredible value, if you want to talk value.
This is part of how I legitimized my front suspension upgrade last April. I was at 75K miles, so, things were a bit worn out anyway. My upgrade was going to require new upper and lower control arms as well as inner and outer tie rods. But, now at 78K miles my entire suspension and steering is only 3K miles old.I am in the camp that if its not broken, don't fix it. Usually everything that comes equipped OEM from any new generation rig (that is relatively leaning towards off-road) has components that will do just fine in the long run.
Past that long run point, things wear out - shocks, tires etc. If somethings broke, and you are replacing it anyway, this is the time to mildly upgrade, if your priorities are still the same.
My 91' was beat down when I picked her up, shot tires (also too big, up(down)graded to 30's), two of the four shocks were hosed (replaced bilsteins off of bay, 340 shipped), stuff that would improve upon the truck in the long run. Older vehicles are going to have more of these issues, and one must choose wisely their platform vs. capitol vs. wants vs. needs when embarking.
Stock height vehicles can get 90% of the places the big boys go, its all in the drivers, spotters... and maybe lockers.
Exactly! My JK is my DD and I like that arrangement. I plan on leaving the drivetrain pretty much as is from the factory, just add a 1" leveling kit to remove the factory rake and 1" more tire when the factory shoes wear out. Done! My other hard-earned pennies will go to storage solutions and safety/recovery gear, and that's a whole bunch of pennies just right there...I am in the camp that if its not broken, don't fix it. Usually everything that comes equipped OEM from any new generation rig (that is relatively leaning towards off-road) has components that will do just fine in the long run.
Isn't that the truth. They did the same thing back in the 90s with the 80 series. Small tires, soft cushy ride, lots of bling.Bigger tires were actually a must for my Trooper. They really dumb it down for import into the US. lol. Stock height was less than that of an outback, it seemed. I think I am running just under a 31.
2 fuses..... omg.Believe it or not, Oliver the Land Rover is pretty much completely stock, not bad for something from 1962. The only modification was to remove the propane system (done long before I got it). The upgrades that should happen are to the electrics It still has the 30 amp generator. That meas that our of three things, headlights, defroster, and windshield wipers I can only run two at the same time. So, fitting a modern alternator is a very common upgrade along with adding a fuse block for accessories as the car only has two fuses.
Nice, they sure have come a long way.2 fuses..... omg.
Here is a 2013 Land Rover LR4 main engine fuse panel... NOT shown is the secondary fuse panel in the passenger footwell, that has probably a dozen more at least.
Chirp, chirp....Plus, I like being an Undercover Overlander.....
