Where I should start on building up my rig
tjZ06
Las Vegas/Palo Alto
mynameisntallowed
Adams
Maintenance ,maintenance, maintenance
This. This all day. Go on the Ford Power Stroke Diesel forums and study-up on the 7.3. It's a GREAT motor, but there are common issues that should be addressed, as well as some nice budget mods that will wake it up and improve MPG as well as reliability. Otherwise, a lot of the recommendations here are solid. I wouldn't go YYYYyyyyuge for an Overland rig. I think because of the size of the Excursion 37"s would be a great size. When you pick suspension I'd prioritize on soft, flexy springs and great shocks to get the most out of the rig off-road but also provide a better ride (one of the few real downsides of those Excursions). Of course, if you're planning a TON of weight (heavy RTT, lots of water onboard, everything AND the kitchen sink packed into that cavernous rear hatch) you will have to pick rear-springs accordingly.
Finally, I'd say lockers and a winch - but that goes for ANY rig, IMHO. For the front for Overlanders I always suggest a select-able locker. We spend way more time on-pavement with Overland rigs than off, and in general a true select-able locker is going to be the quietest, easiest on parts, etc. when not in use, yet the most solid option when you do want to be locked. That said, I'm pretty sure that era SD/X had select-able hubs (IIRC, the stock hubs have auto and locked, but not a true unlocked position), but they can be upgraded to full free-spin which means you negate most of the downsides of things like a Detroit or lunch-box locker. A winch, well the benefits go without saying there.
-TJ
Reactions: OperationSnowball
JimBill
San Benito County, CA, USA
James
Madison
My methodology as follows: (your mileage may vary)
#1 Perform all preventative maintenance, have it in a state of best mechanical operation. Get familiar with it.
#2 Make darn sure you have a matching diameter full size spare tire. I usually get a matching rim from the junkyard so I can rotate it in.
#3 Outfit a basic support kit- fire extinguisher, first aid, tow strap, tools, shovel, jack, emergency communication, etc. Some would say recovery points are part of the basic kit.
#4 Research any vehicle weak points or common issues, address as needed to minimize reliability risk or increase efficiency (upgrade?, attention or modification to driving style?, who knows what?). This is where I usually hit the junk yard and pick up any factory armor or recovery points my rig was not optioned with.
#5 First mod is upgrade the tires (if the vehicle has street tires). At least a mild all terrain pattern suitable for your area.
#6 Get out and hit the trails. You will find out what the vehicle asks for based on what you demand of it. You may be able to predict this right off the bat- lift, winch, rock sliders, auxiliary lights, whatever. Edit: you may find your rig suitable, and decide to spend budget on camping upgrades instead of vehicle upgrades at first. Just get out and see what calls to you.
OB Executive Director
Hello everybody! I am new to overlanding specifically. I have been camping, fishing, hunting, and exploring the Colorado rockies for most of my life and now want to expand my travels using an overlanding rig. The vehicle I have to build upon is a stock 2001 Ford Excursion with 4WD and is equipped with the 7.3 Diesel engine. I am looking for both advice and help in finding the upgrades for my truck. I have been watching videos of overlanding builds on YouTube for hours and hours now but am now genuinely lost on where I should start. Any information you can give me will help tremendously! Thank you all in advance.
Welcome to Overland Bound
Overland Bound Meetups
Overland Trip Planning
Overland Expo Mountain West is this August.https://www.overlandexpo.com/mtnwest
OVERLAND BOUND COMMUNITY
The closest Member Representative is @Neal A. Tew
A local member in Denver that might be able to help you is @the_runn4r
trail_runn4r
US Rocky Mtn. Local Expert. Colorado: Denver Area
Denver, CO, USA
Carlo
Donzelli
Hello Aiden and welcome! I'm based out of Denver too.
Please reach out if you need any help and if you are looking to adventure this is our next planned trip.
tjZ06
Las Vegas/Palo Alto
mynameisntallowed
Adams
This is great, great advice here. I get carried away in mods and "builds" but you can't forget the stuff listed up here. I kind of touched on maintenance and using the vehicle-specific forums to figure out and address the "weak points" in your rig, but JimBill makes it much more clear. I totally overlooked mentioning the matching diameter spare (that is in good shape, not dry-rotted), the basic support kit (which should also include some sort of 12V pump that is actually capable of filling your tires... a gas-station cigarette lighter pump isn't going to do a good job of filling 35"s on a heavy diesel full-sized SUV, for example), and his last point: hit the trails.
As I mentioned, I have a tendency to just jump in with both feet with my builds - doesn't matter if it's a street car, race car, side-by-side, sand rail, or what was supposed to be a mild Overlander. Don't be like me, lol. Get your rig out there (mostly) as-is and go with a group so you can actually push it and see where it gets stuck or hung-up and make decisions based on that. Maybe you find out the clearance at stock height is fine, you just could use a more aggressive tire and real traction devices in the axles. Maybe you decide the rocks and trails like The Rubicon are what float your boat, and you'll want to do more to get your big-rig through those tighter, technical trails. I never found anything my WJ couldn't do on the previous 4" lift (front long-arm, rear stock arms with wishbone spacer) and ~31.7" tires with the stock VariLok diffs in the QuadraDrive system. Yet, I find myself in the middle of a full, semi-custom 4-link setup, hydro bumps, 3-tube bypass shocks, full frame stiffeners, trussed and gusseted JK Rubicon Dana 44s with e-lockers and 4.88s, etc. etc. etc. I don't have any regrets, and the intent is to run the Rubicon with it ASAP... but like I said I never found a situation where my previous setup let me down on the trails I was doing.
So, go out there and enjoy first. Start to get a feel for what your speed of "Overlanding" is. You'll find numerous threads on this forum, and others, debating what "Overlanding" really is, and what it means. I'll let you dig through those, by my $0.02 is it is different for every person and it should be about what YOU want it to be. Maybe it's just taking a mild dirt road out of town to get into nature in your Prius (I'm looking at you @JCWages ) or maybe it's making it through all the winch hills at Fordyce. Either way is a-okay. Until you find what you enjoy most, and whether your rig gets that job done or not, don't go to mod-crazy (again, do as I say, not as I do). The one caveat I'd say, is get good sliders right off the bat. Any rig should have them, but especially lonnnnng wheelbase rigs like yours. You may end up finding dirt fireroads are your speed, and you never actually needed them. But you'll be thankful you have them that one time you accidentally find a slightly more serious trail and you save your rocks/sills, doors, etc. It's a ton of work and money to fix rocker/door damage once it's done, so that is def one place to just get the protection ahead of time. Also, if your specific rig is known for having any of the pans that keep the life-blood in your vehicle (engine oil pan, trans pan, bottom of the radiator, etc.) especially susceptible to damage it's worth skidding those out from the get-go too.
Other than that, get out there and enjoy.
trail_runn4r
Denver, CO, USA
Carlo
Donzelli
Awesome thank you! Will the next planned trip have trails that I should be able to handle?
This is our next official meetup planned for the end of June. You can open the page and see what the plan is! Since we are expecting quite a few people we probably will split the group to run a different range of trails, so you can pick something easier to start.
as long as you have 4WD low range and decent tires you should be fine!
Also keep an eye on the rally point page since sometimes we plan day trips with a shorter notice.
