roots66
Local Expert, Texas USA
Weir, TX, USA
Roots
GMRS: WSGB862
USAF
Nice! Are those the same Plano cases Michael uses? It's helpful to see them in scale. Do they have a rubber gasket for water resistance?
I believe they are the same. I ordered the first set online and got the others at Home Depot when they started selling them in the store. That's the reason for the slight color differences. Mine do not have a gasket, but they still stay dry, even in the back of a pickup bed during a rain storm.
Reactions: SnapshotHero
RJCanyon
California, USA
Bobby
Horne
I just recently bought a pair of Fox factory series 2.5 coilovers with DSC adjusters and plan on buying Camburg upper control arms to go with them...the coilovers are on a 10 week back order though:disrelieved:
RoarinRow
Elk Grove, CA, USA
Rolando
Nispiros
KN6JJS
Picked up a Baofeng BF-F8HP handheld radio to mess with while sheltering in-place. Also waiting on a Jackery 500W portable battery and a 5lb propane tank holder (don't know where I'm going to install it lol).
Reactions: Brett L.
icant4x4heretoo
Hayward, CA
finally pulled 4.90 gears for the Montero in mid March. Only to be sacked due to the pandemic. so no future buys, right now. but I do need manual locking hubs to finish up my regearing.
  • Sad
Reactions: RoarinRow
Sparksalot
Influencer III
4,312
Bastrop County, TX, USA
Rex
Drake
KI5GH
Air Force
Had to order two new headlight assemblies. I just couldn't polish all of the scratches and fog out old ones. Also bought some steel to build a hitch mount folding tire carrier so I can carry two spares.
I did the same thing last year. Wow, what a difference!
RoarinRow
Elk Grove, CA, USA
Rolando
Nispiros
KN6JJS
Waiting on a new cold air intake (CAI). When I bought the truck the previous owner installed a K&N CAI, which is wide open. Instead I am replacing that with an enclosed S&B CAI. I'm supposed to get it today, but doesn't look like it.
Rose
W7FSB
US ARMY Retired
Just picked up my ZF5 5 speed transmission, pedals, and Clutch master cylinder. Next up is getting the flywheel, clutch, starter, and drive shafts. Got shop space opening up in a couple of weeks, so I’ll hopefully have it in by “Field Day”.
I also have a 95 amp alternator and a power steering pump upgrade to install over the next week or so.
Reactions: Sparksalot
Defender 90 Keith
Plymstock, Plymouth, UK
Keith
Pierce
Last thing I bought was a duel ARB compressor. Mounted it under the passenger seat.
Next item I'd like to get is some under belly skid plates.
I bought the same ARB compressor some time ago but havent fitted it yet. I cant find anywhere obvious to fit it but i might be able to make space under the drivers seat.
I have a question. Do you have "remote" hose connection points or will you connect your air hose directly to the compressor each time?
Hyppee and Ziggy Show
Abilene, Texas, United States
Larry
Stockman
At this time, I am connecting at the compressor. Future plans are to have remote connections at each corner with hoses for each corner.
Reactions: kcTrek19
Defender 90 Keith
Keith
Pierce
Id be interested to see how it goes. I was thinking about fitting 1 external remote connection. My concern is does the compressor need much space around it to "breathe"?
Reactions: kcTrek19
Larry
Stockman
I have my compressor mounted under the passenger seat, it is a tight fit, but I have read and seen video's stating that it wouldn't get too hot in that closed space. As far as breathing, it shouldn't be a problem as the end take is on the end of the compressor. My intakes are facing toward the door. So with the door open it should get plenty of air.
Reactions: kcTrek19
Defender 90 Keith
Keith
Pierce
I have a Defender so under the seat means being enclosed in a box. I have to remove the seat base, revealing a sheet od metal which slides out to allow access beneath. I considered fitting a vent in the side of the seat box but wasnt sure whether it would be sufficient. Ive added a web photo of what the seat box arrangement looks like.
LostWoods
Phoenix, AZ, USA
Andrew
lastname
I would definitely consider a vent port. Hell I'd probably do a vent port and a 12v fan because anything worth doing is worth overdoing.
Compressors need a fresh source of air to cool and running them in an enclosed space is a great way to reduce life and runtime.
Defender 90 Keith
Keith
Pierce
Thats whats been running through my mind. I dont really have anywhere else to fit it
Lil Bear
Georgia, USA
Working
Toomuch
Last thing I bought was the Tuff Stuff truck bed rack. Which is now installed. Next thing on the list will be the tent to go on top of the rack. At least that is the plan! The list is very long though!! :tearsofjoy:
