Look up a couple postsNext thing you know, the front seat is coming out.Made my ikamper more comfortable by putting carpet in.
Influencer III
19540
Yeah. Pulling your leg.Look up a couple posts
Steward I
Steward II
10123
Steward II
10123
Off-Road Ranger III
The size of the adapter is not so much of a problem it is the valve core restrictions that slows the flow a Schrader valve normally only inflates at 70 -100 liters/min. We use something similar to this product which removes the core inside the nozzle and massively reduces the time needed to inflate or deflate the tyre.Upgrade the hose on my viair 440p. The clamping nozzle was driving me crazy, never clamped on the tire valve.
So I got a dual hose, spiral hose, and smaller quick fit connectors. Looks good on paper, but hoping the 1/4 quick connects aren't too small and slow down the air flow, the original ones are 3/8".
Difference in size of the quick fit connectors.
Just curious, so i remove the core from stem, then pop on my compressor?The size of the adapter is not so much of a problem it is the valve core restrictions that slows the flow a Schrader valve normally only inflates at 70 -100 liters/min. We use something similar to this product which removes the core inside the nozzle and massively reduces the time needed to inflate or deflate the tyre.
AIRTEC Valve Core Removal Tool - Tyre Safety Inflator (5628367) | eBay UK
TOP AUTO PARTS new CRT ‘Core Retracting Tool’ essentially solves the age-old problem of re-engaging the valve core into a truck or bus valve when the tyre has been inflated. For many years truck and bus tyre inflation has been a significant topic of discussion in the tyre industry, particularly...www.ebay.co.uk
Hope this helps.
Cheers Paul
Off-Road Ranger III
No in fact you attach the compressor to the tyre and then you can remove the valve core inside the device dead simple, I was happy with the fill rate until I used one of these, I suppose the best way to describe the difference is when you want to seat a tyre bead you normally remove the valve core to increase the volume of air and seat the bead quickly ,pretty much all tyre shops will do this then replace the valve stem and inflate to the required psi.Just curious, so i remove the core from stem, then pop on my compressor?The size of the adapter is not so much of a problem it is the valve core restrictions that slows the flow a Schrader valve normally only inflates at 70 -100 liters/min. We use something similar to this product which removes the core inside the nozzle and massively reduces the time needed to inflate or deflate the tyre.
Hope this helps.
Cheers Paul
I didn't seem to have any issues with filling time with the factory viair hose clamp, just that the clamping itself was really bad, but still filled the tires at a decent speed.
Take a look at a Milton Valve. It is a valve stem remover/bypass air chuck. I sort of disagree with another member that it drastically increases your fill rate of your tire. Does it go faster but not a lot. Yes the valve stem reduces the inlet volume but we are talking seconds not minutes. Here is the link and there is a guy on YouTube that timed it and he only gained 15 seconds with the Milton valve.Upgrade the hose on my viair 440p. The clamping nozzle was driving me crazy, never clamped on the tire valve.
Tested out the new dual hose, and they work fantastic! Cut down on filling time by a lot! Usually I'm last to fill (since I'm on 38x13.5x17), but I finished earlier than everyone last time we went wheeling. Very happy with my setup.Take a look at a Milton Valve. It is a valve stem remover/bypass air chuck. I sort of disagree with another member that it drastically increases your fill rate of your tire. Does it go faster but not a lot. Yes the valve stem reduces the inlet volume but we are talking seconds not minutes. Here is the link and there is a guy on YouTube that timed it and he only gained 15 seconds with the Milton valve.
The test starts around the 26 minute mark.
